Staggered Jetting.... #753416
07/20/10 02:34 PM
07/20/10 02:34 PM
tboomer Offline OP
tboomer  Offline OP
Is there any benefits to this??
Re: Staggered Jetting.... [Re: tboomer] #753417
07/20/10 02:50 PM
07/20/10 02:50 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i look at plugs and jet accordingly. if 2 and 4 look rich, i will put a leaner jet over them as an example. if thats what your asking
Re: Staggered Jetting.... [Re: sixpackgut] #753418
07/20/10 03:23 PM
07/20/10 03:23 PM
tboomer Offline OP
tboomer  Offline OP
Thanks,Ray!! Looks like everything boils down to track testing...
Re: Staggered Jetting.... [Re: tboomer] #753419
07/20/10 07:21 PM
07/20/10 07:21 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
We used 8 egts on the dyno, and found the manifold combo needed 1 size larger on the left rear. It's been so many years, I forgot the numbers involved. I reckon each manifold would be different.
Re: Staggered Jetting.... [Re: tboomer] #753420
07/20/10 07:45 PM
07/20/10 07:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its common to stagger jets to balance a manifold...
I use EGTs to do it but I change the manifold runners
to balance the manifold
Re: Staggered Jetting.... [Re: tboomer] #753421
07/20/10 08:27 PM
07/20/10 08:27 PM
Locomotion Offline
Locomotion  Offline
On my 360 I saw a color pattern between cylinders being fed by one side of a Weiand Stealth dual plane and the other. The deeper plane was running leaner. I averaged out the numbers and had 2 or 3 jet sizes difference between the sides. The coloring evened out and I picked up about .03-.05.
Obviously doing it on a single plane would be a little more difficult to figure out. Other factors may also influence things. But basically on a single plane, all cylinders are being fed from a larger, single plenum so differences may not be so obvious without "tools".
