Re: Tubes vs NO Tubes ?? (Slicks)
[Re: 69CHARGERMD]
#752313
07/20/10 08:02 AM
07/20/10 08:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
so i assume whoever mounts them,,,should put lots and lots of powder INside the slick,,,and ON the tube as well....
Just put plenty in there(side walls as well)just coat the entire tire, put the tube in and once the tire is all mounted and aired up... then let the air out again so the tube can move around and neutralize then air them up
