4 spd overdrive #75064
06/17/08 06:09 PM
06/17/08 06:09 PM
New York
moparmatt383 Offline OP
New York
I put in a 4 spd overdrive trans into my cuda today. It is a used unit and the owner said it was rebuilt by liberty gears and had about 500 miles on it. I have two questions.
1. He said that 3rd and 4rth are reversed and the shift rod had to be under the tab comeing out of the trans instead of above it. I could not see how to do this and just set it up normally. So I would shift 1st, 2nd, 4th, 3rd. How can I correct this? Does the rod need to be bent or something?
2. When driving there is a slight wur coming from the trans. I am too young to have seen these cars new and dont know if that is normal ot not. My friend said old trannies have strait cut gears and they tend to be a bit noisy, but I dont know if he knows what he is talking about.
Matt
Re: 4 spd overdrive [Re: moparmatt383] #75065
06/17/08 06:58 PM
06/17/08 06:58 PM
you shift 1-2-3-4
no straight cut gears in a 833/OD trans. just reverse IIRC.
Re: 4 spd overdrive #75066
06/17/08 10:13 PM
06/17/08 10:13 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
you shift 1-2-3-4
The shift pattern is still the normal 'H' pattern. The 3-4 lever on the side of the trans is rotated (flipped if you prefer) 180* and pionts downward, rather than upward as on a non-O.D. A-833 4-speed.
The below is a pic of an O.D. A-833 installed in a van, so the angle of the shift rods is different, but the 3-4 lever (frontmost lever) can clearly be seen pinting downward, as it should be:
You may need to adjust the rod length after you flip the lever to the correct downward-pointing position.
To read some very good info about the New Process A-833 4-speed trans, click HERE
Re: 4 spd overdrive [Re: In_The_Pink] #75067
06/17/08 10:24 PM
06/17/08 10:24 PM
Here's how these things work, and WHY you turn the 3-4 shift lever is DOWN because that reverses the shift mechanism operation.
When you put the lever in "3rd" position, the reversed lever actually puts the transmission in the "old" "4th" gear (straight through) position, and when you put the lever in 4th, the reversed linkage actually puts the transmission in the old "3rd" gear position, which now is comprised of the overdrive ratio.
A little clue for ya. If you have any hard pulling or trailer towing, the "new" 3rd gear--the straight through gear--is much much stronger than the OD 4th gear.
Re: 4 spd overdrive #75068
06/18/08 10:52 AM
06/18/08 10:52 AM
New York
New York
I know you shift 1-2-3-4, lol. I guess I didnt word it right. My question is how can you reverse the 3-4 rod on an E body so I can shift in a normal pattern because it doesnt seem possible with out some sort of modification. Also there will be no towing in my Cuda.
Thanks,
Matt
Re: 4 spd overdrive [Re: moparmatt383] #75069
06/18/08 11:19 AM
06/18/08 11:19 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
all you have to do is flip the 3-4 lever upside down. it should fit in there.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 4 spd overdrive [Re: moparmatt383] #75070
06/18/08 12:44 PM
06/18/08 12:44 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Thanks,
Matt
You don not need to reverse the shifter rod, just rotate the 3-4 lever on the side of the trans 180*- make sure it's pointing downward.
You may need to add additional length to the 3-4 shifter rod after you rotate the lever. If after rotating the lever the rod is now too short and there is not enough length to allow for safe operation, you'll need a longer shifter rod. I don't know the ins and outs of E-bodies, but you may need a different 3-4 shifter rod entriely if there is crossmember interference with the new lever position.
Surely someone here has an E-body with the O.D. A-833.
Re: 4 spd overdrive [Re: In_The_Pink] #75071
06/18/08 11:36 PM
06/18/08 11:36 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
I ran my ex's 74 B-cuda with an 833OD. There shouldn't be any interference with the crossmember. As mentioned, the rod may need to be a tad longer, though...
2 Demons...no, not my kids!
Re: 4 spd overdrive [Re: 4speeds4me] #75072
06/19/08 08:20 AM
06/19/08 08:20 AM
New York
New York
I am going to check today so I'll let you guys know.
Matt
