The truth about dana 60's #750646
07/17/10 07:35 PM
07/17/10 07:35 PM
U.S.
moparniac Offline OP
U.S.
http://www.yellowbullet.com/forum/showthread.php?t=264175
"After 1000's of street miles and 100's of passes from a small block street driven to a 3700 lbs NOS hemi making 1200 hp, to a 3500 lbs blown hemi making 1700 hp to a 3250 lbs making 2300 hp finally broke the pinion.... its been in there since 2004. The housing and everything else is fine- Its not just a OEM Dana 60 its a moser 60 with bullet caps 40 spline axles and a bullet cover..... all of the good stuff! Although over the winter I may install a 11 inch MW set up, for now I installed a new ring and gear I even had it cryoed! Even if I keep the dana 60 I'm sure its fine I guess at the power level I just have to change the gear set every season!"
Mopar Performance
Re: The truth about dana 60's [Re: moparniac] #750647
07/17/10 08:15 PM
07/17/10 08:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
" Its not just a OEM Dana 60 its a moser 60 with bullet caps 40 spline axles and a bullet cover..... all of the good stuff!
don't you think you better reword that ?????????????
Re: The truth about dana 60's [Re: Quicktree] #750648
07/17/10 09:45 PM
07/17/10 09:45 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
What size bullet....I have a Dana and a .38..is that big enough??? LOL
If you like drag racing, support your local track.
