airgrabber Q.....70 roadrunner #74907
06/17/08 09:10 AM
06/17/08 09:10 AM
MA
limelight440 Offline OP
MA
Began resto of airgrabber hood yesterday.
Does the square trim ring with the studs for the air cleaner cover & the door hinge come off the hood?
If so, How...It looks to want to come off but I don't want to pry
Thanks,
Mike
Re: airgrabber Q.....70 roadrunner [Re: limelight440] #74908
06/17/08 09:22 AM
06/17/08 09:22 AM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
No, it's spot welded on.
Re: airgrabber Q.....70 roadrunner [Re: limelight440] #74909
06/18/08 11:26 AM
06/18/08 11:26 AM
MA
MA
That certainly makes restoring this hood alot of work.
Can you/someone tell me what function the air soleniod serves. It seems un-needed. Does the
system look for power from the run side of the ignition before the airgrabber will open??
Forgive me but,
just turned 25,
my experience with these cars is limited
Thanks Again
Re: airgrabber Q.....70 roadrunner [Re: limelight440] #74910
06/18/08 11:40 AM
06/18/08 11:40 AM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
I believe it allows the scoop to close when the car is turned off with the scoop up (when it sees the ignition cut it releases the vacuum).
Also, not all cars have them, not sure why.
