Need 67 Coronet R/T kickdown linkage - alternatives ? #748868
07/15/10 01:37 PM
07/15/10 01:37 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
I'm finding it hard to locate a kickdown linkage for my 67 coronet R/T (440) aside from year one (very very pricey).
Is there anything else that would suffice ?
Aftermarket, Lokar, etc ?
THanks
Re: Need 67 Coronet R/T kickdown linkage - alternatives ? [Re: Texican] #748869
07/15/10 02:01 PM
07/15/10 02:01 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Bouchillon Performance has a nice kick down kit.
Re: Need 67 Coronet R/T kickdown linkage - alternatives ? [Re: Texican] #748870
07/15/10 03:33 PM
07/15/10 03:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Year One is what is available as reproduction, you should be able to find it cheaper from one of the many repop parts suppliers .
Should you choose the cable route skip the lokar , it's generic and doesn't operate a mopar properly as supplied from all the posts about it I have read.
Re: Need 67 Coronet R/T kickdown linkage - alternatives ? [Re: JohnRR] #748871
07/15/10 06:58 PM
07/15/10 06:58 PM
scratchnfotraction Offline
Bouchillon cable is very nice kit..well worth the $
or a full manual low band apply valvebody from CRT
I went with a crt VB in my 88 440 truck build
Re: Need 67 Coronet R/T kickdown linkage - alternatives ? [Re: scratchnfotraction] #748872
07/19/10 10:07 AM
07/19/10 10:07 AM
MI
Jerseyboy Offline
Jerseyboy  Offline
MI
I run the lokar stuff on my Coronet. Did both the trans and the throttle cable. Nice small bracket, braided cable covers and they work great. Got it through Mancini.
Re: Need 67 Coronet R/T kickdown linkage - alternatives ? [Re: Texican] #748873
07/19/10 10:19 AM
07/19/10 10:19 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm almost positive A+A has it - though they don't show it on the site
http://www.aandatrans.com/Departments/Chrysler-727-Trans.aspx
