best cam for a mild 340
#74856
06/17/08 07:24 AM
06/17/08 07:24 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
got a phone call from the guy that bought my Swinger. He was wondering what cam he should get. So he you small block guys go. 69 340, 10.5:1, mildly ported J-heads, 1.6 roller rockers, RPM air gap, TTi headers 3" X-pipe, MSD distrib, 727 with mild stall and 3.55's He wants to keep the 3.55's. Now it has the stock 340 cam. I got the thing to run 13.80 w/ a 750DP and 14.08 w/ a carter 600. Carb recommendations taken too.
Re: best cam for a mild 340
[Re: Mr.Yuck]
#74857
06/17/08 08:18 AM
06/17/08 08:18 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
comp XE262 or XE268, I'd use an 800cfm eddie thunder series AVS or a demonsizzler t-quad
[Re: patrick]
#74859
06/17/08 08:39 AM
06/17/08 08:39 AM
Mr.Yuck
Brookeville, Md
800 eddy on a mild 340?? seems a tad big. I recommened a 650DP but then again I don't care for vacuum carbs. I'll check into that cam.
[Re: Mr.Yuck]
#74862
06/17/08 10:15 AM
06/17/08 10:15 AM
Posts: 8,144 Arkansas
340727dart
Arkansas
Get a Lunati Voodoo #60403. That's what I've got in my 340 and love it.
Product Description Hydraulic. The most awesome 268 cam ever produced! Out-powers all others! This High Performance street cam likes 2400 RPM stall, 700 cfm carb, dual plane intake and headers. Makes un-equaled power to 6200 RPM with proper valve springs. Very strong cam with great street manners.
Advertised Duration (Int/Exh): 268/276 Duration @ .050 (Int/Exh): 226/234 Gross Valve Lift (Int/Exh): .494/.513 LSA/ICL: 110/106 Valve Lash (Int/Exh): Hyd/Hyd RPM Range: 1800-6200
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
[Re: 340727dart]
#74863
06/17/08 10:17 AM
06/17/08 10:17 AM
dogdays
[Re: Mr.Yuck]
#74864
06/17/08 11:37 AM
06/17/08 11:37 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I can't think of anything negative to say about my Scott Brown 226/238 @ .005" 270/288 custom stick. Excellent idle and in-gear vacuum (11-3/4"hg in D)and it pulls past 6k. Very good street manners.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#74865
06/17/08 12:08 PM
06/17/08 12:08 PM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
Straightline went out of business.
[Re: AdamR]
#74866
06/17/08 12:23 PM
06/17/08 12:23 PM
YO7_A66
Indiana
Scott can still be contacted for cams scottybrown@vtcompetitionengines.com
