Valve Clearence/Cam Question #746985
07/12/10 09:57 PM
07/12/10 09:57 PM
Nanuet, NY
3
383BeepBeep Offline OP
Nanuet, NY
Currently my 383 has a 292/.509" purple shaft(not through my choice), and 452 heads with the felpro 8519 head gasket. The block was zero decked and has flat tops in it. I have a set of Eddy heads but the clearance was a no go when mocked up last year. I am putting a Lunati 60303 cam in. With the Lunati will I have enough P/V clearance? Thanks
1969 Plymouth Roadrunner - 383- 4 Speed - Dana 60 4:10
Re: Valve Clearence/Cam Question [Re: 383BeepBeep] #746986
07/13/10 10:44 AM
07/13/10 10:44 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
As a rule of thumb with stock pistons 286 degree duration is usally max with early motors with flat tops. Since you have zero decked the motor you should do a clay test. The Lunati is 265/276 494/513 I believe.
