Re: RACERS using OPEN trailers,,,,question ?
[Re: tboomer]
#746660
07/14/10 08:17 AM
07/14/10 08:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Great thread!! I tow an open with my Ram 1500...If the car is not loaded right..It sways all over the place...Where can a person find these bars??
Ted if its swaying like that... pull the car forward more to put more weight on the tongue... yes the EQ bars help but if the trailer isnt loaded right there isnt enough sway control in the world that can correct a negative tongue weight(it might help but it would still be a white knuckle drive) if you mount a front chock block at the right point on the trailer all you would do is pull up and bump into it then tie down
[Re: MrMopar95]
#746662
07/14/10 08:24 AM
07/14/10 08:24 AM
Posts: 12,120 City of Champions
Prostock
City of Champions
only thing i did was measure ground up to my hitch and ground up to my trailer, and bought the proper drop down REESE hitch ball. so that the trailer remains perfectly level, i hate seeing trailers that dont line up at all, either hitch is too high and the trailer does a wheelstand or its too low and its nose diving haha... its very easy to figure out, other than that make sure you got all your lights working and tires filled up and even, and trailer brakes adjusted. should be GOLDEN!
You can see in this photo the trailer is alil low in the front, my drop down hitch is for a brand new econo trailer i borrowed, same one im buying, this is my uncles trailer it needs a taller hitch ball. but it still towed great.
I agree with Nick. Heck, my tow setup is almost exactly the same, including a white diesel ram and a econotrailer!
[Re: MR_P_BODY]
#746663
07/14/10 08:27 AM
07/14/10 08:27 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Open trailer towing with a heavy Duty Ram 2500, no EQ hitch, but I have one to put on. JUsy never felt like needed it.
I have a tire stop bolted to the bed of the trailer so I load the race truck in the same spot everytime, a couple inches for or aft can make a big diff.
I also slid the ball all the way into the receiver and drilled a new hole for the pin...It was sticking out 3"...Leverage is leverage.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Kam*Kuda]
#746664
07/14/10 08:30 AM
07/14/10 08:30 AM
MR_P_BODY
Here is a list
http://www.nationaltrailersupply.com/Weight-Distribution-s/106.htm?gclid=CK7V-av-6qICFRY75QodAlrEdA
what are the difference in distribution hitches? I see 600, 800 and 1000lb Round or Trunnion style?
How do you choose?
The different weight bars are for what you want to lift... if you want to take a 1000 lbs off the tongue you would use the 1000 lb bars... the trunnion is just a different style bar... you have to have the proper bar for your hitch... I like to stay with the manufactures own bars.. ie Reese... Drawtite and so on that way they mount correctly ... if you get bars that are a little light for your weight you will pull the bars up farther which makes the chains shorter which really helps the anti sway BUT you can bind going around tight corners
