Page 6 of 7 1 2 3 4 5 6 7
Re: GTS M code back home [Re: CSK] #746610
03/22/12 05:34 PM
03/22/12 05:34 PM
sst404b Offline OP
sst404b  Offline OP
Need a heater hose bracket, coil bracket, door mirror, headrest, to name a few. Plus need to detail grille and headlight bezels, hood trim, rear glass trim, and,and, man I'm getting tired thinking about it.
Re: GTS M code back home [Re: sst404b] #746611
03/22/12 06:19 PM
03/22/12 06:19 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Formula S 4 speed car for sale in the a-bodies on here.
But its just a lowly 383
Re: GTS M code back home [Re: CrazyD] #746612
03/22/12 06:23 PM
03/22/12 06:23 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Is the sheet metal shield on the brake metering block factory? Anyone have a picture of the shield off the car?
Original shield
Re: GTS M code back home [Re: JohnRR] #746613
03/22/12 06:24 PM
03/22/12 06:24 PM
JohnRR Offline
JohnRR  Offline
another
Re: GTS M code back home [Re: JohnRR] #746614
03/22/12 06:24 PM
03/22/12 06:24 PM
JohnRR Offline
JohnRR  Offline
last one
Re: GTS M code back home [Re: JohnRR] #746615
03/22/12 08:36 PM
03/22/12 08:36 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I think that is one of the best colors you could have on a Dart
Re: GTS M code back home [Re: JohnRR] #746616
03/23/12 02:26 PM
03/23/12 02:26 PM
sst404b Offline OP
sst404b  Offline OP
Thanks for the shots of OE heat shield. Thats the first real one I've seen. It looks like the repo is real close.
Ray
Re: GTS M code back home [Re: sst404b] #746617
05/21/12 10:48 AM
05/21/12 10:48 AM
sst404b Offline OP
sst404b  Offline OP
I've been working on the Dart here and there and it's at the point where I can start driving it and working the bugs out. I'm still looking for a few parts, but it's close. Also this thing is a handful under power, now I know why so few of these survived.
Re: GTS M code back home [Re: sst404b] #746618
05/21/12 10:52 AM
05/21/12 10:52 AM
sst404b Offline OP
sst404b  Offline OP
I took a few pics of the two together.
Re: GTS M code back home [Re: sst404b] #746619
05/21/12 10:54 AM
05/21/12 10:54 AM
sst404b Offline OP
sst404b  Offline OP
Q5 383 auto
Re: GTS M code back home [Re: sst404b] #746620
05/21/12 11:01 AM
05/21/12 11:01 AM
sst404b Offline OP
sst404b  Offline OP
B5 440, Big difference in the way these two cars run, the 440 car is a beast
Re: GTS M code back home [Re: sst404b] #746621
05/21/12 11:06 AM
05/21/12 11:06 AM
sst404b Offline OP
sst404b  Offline OP
In 1969 this was your only clue that you were about to get thumped'.
Re: GTS M code back home [Re: sst404b] #746622
05/21/12 11:09 AM
05/21/12 11:09 AM
sst404b Offline OP
sst404b  Offline OP
The interior
Re: GTS M code back home [Re: sst404b] #746623
05/21/12 11:11 AM
05/21/12 11:11 AM
sst404b Offline OP
sst404b  Offline OP
Last for now.
Re: GTS M code back home [Re: sst404b] #746624
05/23/12 12:58 AM
05/23/12 12:58 AM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
Beautiful job!
Re: GTS M code back home [Re: Airgrabber] #746625
05/27/12 07:22 PM
05/27/12 07:22 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
That is one sweet M, and it's in a good home now. I had one,origionally bronze with a white gut, origional motor long gone. Found out afterwards, it was a Mr. Norms car. I like yours better.
Re: GTS M code back home [Re: sst404b] #746626
05/27/12 08:02 PM
05/27/12 08:02 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
VERY NICE CARS, i havent found anymore info on your car,but my daughter found a pic of mine at houston international after i had sold mine
Re: GTS M code back home [Re: CSK] #746627
06/22/12 11:26 PM
06/22/12 11:26 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
That car looks spectacular!! You must be loving life driving that car!
Re: GTS M code back home [Re: 69Cuda340S] #746628
08/02/12 04:55 PM
08/02/12 04:55 PM
sst404b Offline OP
sst404b  Offline OP
I've been driving it around a few weeks now and it's a blast. The car tries to run a little warm but it's been hot down here it souteast Texas, so can't complain.
Ray
Re: GTS M code back home [Re: sst404b] #746629
08/02/12 04:59 PM
08/02/12 04:59 PM
sst404b Offline OP
sst404b  Offline OP
It's first time out with the boys
Ray
