How do YOU dry out your alky motor?
#746253
07/12/10 09:10 AM
07/12/10 09:10 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Been letting mine die from fuel starvation, then crank after a few seconds to fire off the last of the fuel dripping from the lines. Not totally satisfied I am getting all the moisture out as noted by the cylinders/rings. What is your method, and ring cylinder wall life?
Re: How do YOU dry out your alky motor?
[Re: gregsdart]
#746256
07/12/10 09:54 AM
07/12/10 09:54 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
ever consider running dual system with gas for warm ups and shut downs ?
home of the Sox and Martin Hemi Duster
[Re: Diablo]
#746260
07/12/10 01:48 PM
07/12/10 01:48 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I pull the barrel valve about 3/4 shut. Run it cycling the water pump and fan to build some heat near 200 degrees. Then close the barrel valve all the way, let it die from lake of fuel then I pull the breathers and any valve cover vents and let it steam out. Seems to really help..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: afxcoronet]
#746264
07/12/10 09:57 PM
07/12/10 09:57 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I've always just got the motor up to 180 and water and alcohol will evaporate out on it's own.
So on my last pass I will cycle off the water pump and fan to get the temp up over 180 when I get back to the trailer. Make sure that I get it aligned with the trailer so I don't have to start it again after I shut it off and the oil look as clean as the day I put it in.
I used to change my oil a lot because everyone else did but now I'm using synthetic oil and I haven't changed it yet this year and I probably won't. I will change the filter a time or two, cut it open to make sure everything looks good but the oil can't be broken down, I doubt 300 passes is equivalent to 500 street miles. (sorry not sure why I got off on that)
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
