8 3/4 Ring and Pinion life
#744671
07/10/10 10:04 AM
07/10/10 10:04 AM
Posts: 344 Burlington, Ontario Canada
Dave_S
What is a safe change-out time for Richmond R&P in a 8 3/4? I heard second-hand that Richmond recommends 300 passes but haven't been able to confirm it. I have changed mine at 300 passes twice now but have stepped up to a trans brake and have more power than before. It's a '742 case with M/W cap and arp cap studs. Thanks in advance BUT I'm not ready for a Dana yet and will never put a 9 inch in my car.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
Re: 8 3/4 Ring and Pinion life
[Re: Dave_S]
#744673
07/10/10 10:10 AM
07/10/10 10:10 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Will depend on the weight of the car.... I have well over 300 passes but my car is light with the 742 alum center
[Re: Dave_S]
#744675
07/10/10 09:16 PM
07/10/10 09:16 PM
Posts: 43,255 Bend,OR USA
Cab_Burge
If I was you I wouldn't make any more than 100 passes on the Richmonds, especially with the trans. brake now. Did you install a backbrace on your housing yet? If not it will need with the transbrake I'm a diehard 8 3/4 lover, I've used them in a lot of cars over the years, I have broken them also Axles, ring and pinons (a bunch), stock caps, posi units and posi side gears, I severaly twisted the 8 3/4 housing(not back braced ) up in my street car, 1971 duster that had ran 10:34 ET at 128.6 MPH on ET Street Radials corked up on Oregon pump gas motor only. That car has a cut down 3/4 ton Dana 60 in it now, Best thing I've done to the drivetrain in that car besides installing ladder bars and coil over rear suspension
[Re: Cab_Burge]
#744677
07/11/10 08:00 PM
07/11/10 08:00 PM
Dave_S
I forgot to add, It has a back brace and syn fluid.
