Who is a good 833 trans rebuild company or person #744222
07/09/10 06:16 PM
07/09/10 06:16 PM
Oshkosh WI
barrakudaman Offline OP
Oshkosh WI
looking for some refrences for a trans rebuild shop. I have a hemi 833 transmission that has quite a bit of shaft play. Or is this something i can fix. Thanks
Re: Who is a good 833 trans rebuild company or person [Re: barrakudaman] #744223
07/09/10 06:30 PM
07/09/10 06:30 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
input shaft, cluster shaft or output shaft ??
I am truckless..
Re: Who is a good 833 trans rebuild company or person [Re: barrakudaman] #744224
07/09/10 06:47 PM
07/09/10 06:47 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
With a service manual, some advice from brewers or passons, and some of the people on this site, I'm sure you could do it yourself. I did two of them. Prior to that I had never done one and both work mint.
Re: Who is a good 833 trans rebuild company or person [Re: torkrules] #744225
07/09/10 06:51 PM
07/09/10 06:51 PM
Oshkosh WI
Oshkosh WI
input shaft
Re: Who is a good 833 trans rebuild company or person [Re: barrakudaman] #744226
07/09/10 08:47 PM
07/09/10 08:47 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Might be normal. They have side play,the pilot bushing/bearing takes care of that when the trans is installed. Is the trans making noise or did you just notice the play while checking out the trans?
Re: Who is a good 833 trans rebuild company or person [Re: Ply72rr] #744227
07/10/10 07:45 AM
07/10/10 07:45 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Keisler/Tremec 5 Speed and be done with it.
You will be glad you did.
Re: Who is a good 833 trans rebuild company or person [Re: Ply72rr] #744228
07/10/10 08:32 AM
07/10/10 08:32 AM
Truckville, the capital of NY
85_Ram_4speed Offline
I agree. Because of the bearing setup in the front, when the trans is out of the car, play is evident, even on a fresh build. For the engine side of the input shaft, I prefer to use the new style sealed roller bearing setup from a Magnum engine truck---i want to say the part number is 53009180AB. I feel its a better way to go over the pilot bushing.
If have run this trans and it made no noise, its probably all fine inside. However if you do not know the history of the trans, a rebuild wouldn't be a bad idea. Like said, its not really hard to do and can make a world of difference in the feel of the trans when shifting. Some special tools (like flat snapring pliers) are required, but the experience is well worth it.
If you prefer just to send the unit out, in my eyes, Jamie Passon is the best. Unfortunatly, just about everyone went to Carlisle this weekend so you'll probably have to wait a bit to call him.
Outcast Dodge guy.
Re: Who is a good 833 trans rebuild company or person [Re: 85_Ram_4speed] #744229
07/10/10 09:18 AM
07/10/10 09:18 AM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Brewers Performance
Joey
Re: Who is a good 833 trans rebuild company or person [Re: jake4cars] #744230
07/10/10 09:29 AM
07/10/10 09:29 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Brewers for sure...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: Who is a good 833 trans rebuild company or person [Re: sycboi] #744231
07/10/10 09:40 AM
07/10/10 09:40 AM
Oshkosh WI
Oshkosh WI
I just picked up the trans from iola car show. Guy said it was in a running car. Thanks for the info.
Re: Who is a good 833 trans rebuild company or person [Re: barrakudaman] #744232
07/10/10 12:52 PM
07/10/10 12:52 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
Jamie Passon I hear the Brewers is good too.
1981 Dodge D150 360 auto
