A518 big block trans #744160
07/09/10 04:33 PM
07/09/10 04:33 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
Here's one that always get some opinions flowing.
Back in 96 I wanted an overdrive Torqueflite for my 440and of course there were none. Still aren't, in fact. There wereguys selling adapter kits but I don't like adapters so I cut off the bellhousing from a big block 727 then welded it to a small block A518.
This is the hydraulic (non-electronic) shift version of the 46RE.
Did it work? Yes - very well. I just took it out after 12+ years. No leaks or other problems of any sort. I run a 4.10 gear which turned into about a 3:1 ratio after the OD is engaged.
I also learned that a lot of the talk you hear about factory machining being poor is just wrong. Back then I indicated about 20 transmission cases and found they were all within .005" and most were around .002-3.
This particular case showed about .0015" runout.
Re: A518 big block trans *DELETED* [Re: GregCon] #744161
07/09/10 05:12 PM
07/09/10 05:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Post deleted by stumpy
Re: A518 big block trans [Re: GregCon] #744162
07/09/10 05:33 PM
07/09/10 05:33 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
id like to know how you got the case within spec ( lined up)
Re: A518 big block trans [Re: GregCon] #744163
07/09/10 05:39 PM
07/09/10 05:39 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
That's awesome!
Re: A518 big block trans [Re: stumpy] #744164
07/09/10 06:39 PM
07/09/10 06:39 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
I made a jig,essentially, that registered on the dowel pin holes in the bellhousing and the pump housing register on the trans. It held it all in alignment during welding. The proof of that is in the fact that the runout was very minimal after it was all done. Also after welding I put the whole case in the lathe and trued up the face so it is perpendicular to the C/L of the crankshaft and parallel with the engine block mounting face.
I actually made two - the first one had some slight problems I chalked up to learning. It would still work, though.
Two things that are interesting:
1) There is a certain point on a 727 case where small and big block cases 'come together' - that's where you make the cut. The match up is almost perfect at that point.
2) When welding the two pieces together, a lot of amperage is needed due to the large heat sink effect of the aluminum. .080" disappeared in the process. What that means is I had to leave .080" extra on the bellhousing (or on the case) and it would 'suck in' during weld to arrive at the desired final case depth (the distance from the face of the bellhousing to the face of the pump register).
One other thing - the aluminum of the 727 case, being over 20 tears old, had a lot of oil soaked in it. No matter how much it was cleaned ahead of time, it would 'boil out' and made welding tough.
Re: A518 big block trans [Re: GregCon] #744165
07/09/10 07:30 PM
07/09/10 07:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Before UltraBells became available, adapters or welding were the only way to make a BB 518. Here's a pic I took at a local swap meet about 10 years ago.
Re: A518 big block trans [Re: John_Kunkel] #744166
07/09/10 07:32 PM
07/09/10 07:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Inside bell view.
Re: A518 big block trans [Re: John_Kunkel] #744167
07/09/10 07:36 PM
07/09/10 07:36 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
ok, what would you charge to do this?? or give us directions on how to do it.. Plzzzzzzzzzzzzz
Re: A518 big block trans [Re: Dakota_Don] #744168
07/10/10 03:40 AM
07/10/10 03:40 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Unless you've got the time, inclination and spare 727 to cut, why would you not just buy the jw ultrabell?
Re: A518 big block trans [Re: DaytonaTurbo] #744169
07/10/10 08:04 AM
07/10/10 08:04 AM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
The Ultra bell has a few issues you might or might not be able to live with. First, I believe it is limited in the size of torque converter it can hold; it is smaller internally than a stock bell.
Second, it attaches to the trans via the pump bolts. These bolts are small (5/16" diameter), long, and were never intended to anything but attach the pump to the case. If you look at the case itself, several of the threaded bosses are very minimal - there's not much meat around them.
As a minimum, I would HeliCoil all of the holes to get steel threads. I'd be surprised if you could get 50,000 miles in a street driven application without some sort of pump related problem (like leaks) or even a case/bell separation issue.
Also, as a race piece, I do not believe it offers all of the factory bosses. So if you have a column shifter or kickdown linkage you might be forced to rework your linkage which is seldom pretty.
Re: A518 big block trans [Re: GregCon] #744170
07/10/10 08:46 AM
07/10/10 08:46 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
There was a company in Iowa I believe that is selling 518's converted to BB and they are doing it exactly the way you did.
Kevin
Re: A518 big block trans [Re: GregCon] #744171
07/10/10 08:50 AM
07/10/10 08:50 AM
North Dakota
440abody Offline
440abody  Offline
North Dakota
Here is a place that does them, and a few years ago MCG featured one in the magazine. I believe from a place place in Iowa.
http://phoenixtrans.com/html/chryslertrans.html
Chrysler A-500 A-518
Introduced in 1989 and 1990 these transmissions are essentially the good, strong 904 and 727 trans with .69 to 1 overdrive added to the rear. 4th gear is controlled electrically, requiring a simple toggle switch to engage 4th gear or lockup in stock applications.
Dimensions are very close to the 904 and 727 except for length and extra bulk in the housing to accept the overdrive assy. All linkages including kick down are the same as the 902 and 727 easing swaps considerably.
A-500 Overall Length 38” Face to mount distance 24 3/8 Ratios: 1st 2.74, 2nd 1.54, 3rd 1.00, 4th .69
A-518 Overall Length 38” Face to mount distance 25 1/4 Ratios: 1st 2.45, 2nd 1.45, 3rd 1.00, 4th .69
Models and Pricing:
#PTA500HD
Our heavy duty replacement trans features durability and shift improvement modifications that bring this transmission's rating up to 325 horsepower. Included is our 1800-2000 stall converter. $1539.85
#PTA500SS
Our street/strip model capable of up to 395 horsepower is modified with high performance bands and clutch packs, special valve body, and servo modifications. Included is our high performance converter with stall speeds up to 2800 rpm. A great trans for the Magnum crate engines. $1745.85
#PTA518HD
Our heavy duty replacement trans for the 318 and 360 engines. This trans features heavy duty components and shift modifications for engines up to 395 horsepower. Comes with heavy duty torque converter with 1800 rpm stall speed. $1642.85
4x4 option ADD $206
#PTA518SS
Our street/strip model capable of 500 horsepower is the choice for the high output engines or those who desire the very strongest trans for their car. This trans features high output bands and clutch packs, valve body and servo modifications, and available stall speeds to 2800 rpm with our high performance lockup torque converter. $1848.85
4x4 option ADD $206
We can build the 518 to use behind the B and RB series engines. ADD $606.67 to the trans price for this option.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: A518 big block trans [Re: 440abody] #744172
07/10/10 09:14 AM
07/10/10 09:14 AM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
From the looks of it they are just using an UltraBell.
Re: A518 big block trans [Re: GregCon] #744173
07/10/10 04:04 PM
07/10/10 04:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 11" converter is in common use anyway, not a big issue.
Remember the Clutchflite used behind nitro funny cars? Never heard of a pump bolt failure.
This is a legitimate issue but cable-operated shifters and TP are popular even with stock 727 installations.
Re: A518 big block trans [Re: John_Kunkel] #744174
07/10/10 04:37 PM
07/10/10 04:37 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
Like I said, this topic draws a lot of opinions.
I never look to drag applications for what will fly on the street. A nitro car is forgiven if it blows up every 15 seconds, a streetcar isn't. I have 4 Clutchflites in the garage; all of which look like they've had some unhappiness in the front pump bolt area.
If you are willing to forego your stock shifter and use a cable operated kickdown then the Ultra is not an issue. I've never found a cable kickdown that really worked that well, though.
Re: A518 big block trans [Re: GregCon] #744175
07/10/10 04:40 PM
07/10/10 04:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If a clutchflite will handle it then street use is no problem. I've had no problems with installing and using cable kickdowns for myself and customers for years.
Re: A518 big block trans [Re: stumpy] #744176
07/10/10 10:02 PM
07/10/10 10:02 PM
SoCal
GearheadJake Offline
SoCal
Just for those who don't mind using a well-engineered adapter (like I did), here's an article where it was done -
https://home.comcast.net/~ehostler/A518/Part_1.pdf
The company (jvxracing dot com)has been around for a while, has great customer feedback, and the kit is all inclusive. I only had to build a shift cable bracket and have the driveshaft shortened. My setup (30 foot motorhome, beefed 440, + car trailer) has been problem free for 2 years & 17k miles.
Re: A518 big block trans [Re: GregCon] #744177
10/09/13 10:14 AM
10/09/13 10:14 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
This is a very timely post. I have a 518 laying on the floor here that I was getting ready to yank apart and prep to go in the Cuda. (street/strip car)
If you were to use the Ultrabell, would it help to spot weld the tranny to the new 'bell as well as Heli-Coil the pump mounting holes? The spots could be cut in the event that that tranny needed to come apart.
Master, again and still
Re: A518 big block trans [Re: DaveRS23] #744178
10/11/13 11:31 PM
10/11/13 11:31 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
I like the idea of welding a 727 bell onto the 518.
Just a little leery about where to remove the bells.
Re: A518 big block trans [Re: drew72] #744179
10/12/13 12:04 AM
10/12/13 12:04 AM
smyrna,tn
draginmopars Offline
smyrna,tn
i've been using a brake lathe to cut off the bells
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
