EBody interior door trim seals
#743352
07/08/10 02:51 AM
07/08/10 02:51 AM
Posts: 43 Darwin, Australia
Billo
Darwin, Australia
Howdy all.
Has anyone had any trouble with ebody door trim chrome strips/window seals popping off when you wind the window up? If so how did you fix it? Wondering whether to cut the chrome strip from the seal & attach the seal to the door frame seperately. These seem to be new door trims also.
Thanks,
Bill
Cheers,
Bill
Re: EBody interior door trim seals
[Re: Billo]
#743353
07/08/10 11:05 AM
07/08/10 11:05 AM
Posts: 1,912 Anchorage, Alaska
Iceman01
Challenged
Challenged
Anchorage, Alaska
Yes, I do on the driver's side. The front wants to pop off if I try to roll it down or up without holding onto the trim. It was real bad when first installed, but after a year it has kinda molded into shape and now holds better -- more of a minor PITA.
I haven't tried for a permanent fix yet. I think it's just a matter of adjusting the door glass to not put so much pressure toward the interior side. At least that's the assumption I'm making after comparing its operation to the passenger side (which works fine).
Until total honesty is on the table, we're not even talking about reality...
[Re: Iceman01]
#743354
07/08/10 07:27 PM
07/08/10 07:27 PM
Billo
Darwin, Australia
Thanks for the reply sir. Nice car if thats your green one. Hows Alaska? I'm in Darwin Australia in the tropics. My Barracuda is the only one up here & is getting a lot of attention.
Cheers,
Bill
[Re: Iceman01]
#743356
07/09/10 10:03 AM
07/09/10 10:03 AM
Billo
Darwin, Australia
I need to get some current photos. This is when it was in Ohio. I found the car on this website
& got it in April.
Cheers,
Bill
[Re: Billo]
#743357
07/09/10 10:07 AM
07/09/10 10:07 AM
Billo
Darwin, Australia
Don't know how to attach a few photos at once. Tim in Ohio did the work, hes on here under Georgia - his wife. He did a nice job.
Cheers,
Bill
[Re: Billo]
#743359
07/09/10 10:24 AM
07/09/10 10:24 AM
Billo
Darwin, Australia
And finally, heres one of the donk. Its still apart at the moment getting a new cam - Lunati Voodoo 513/533, hone, new rings, bearings & an airgap manifold with a 750 dp. It will be a tuff streeter. I still want to be able to go for an hour long drive down the track for a counter meal at the pub though. Should be ready in a week.
Cheers,
Bill
[Re: Billo]
#743360
07/09/10 11:28 AM
07/09/10 11:28 AM
Iceman01
Challenged
Challenged
Anchorage, Alaska
Nice! Must be a rare sight in your part of the world.
