Testing firing a 360 #743249
07/08/10 12:09 AM
07/08/10 12:09 AM
Mount Airy, Maryland
scrag Offline OP
scrag  Offline OP
I am trying to test a 360 and see if it is a good engine or if I need to bebuild it. I do not have a transmission for it but have the Torque Converter and flex plate. Is there anyway I can test start it with out the 904 being present?
Re: Testing firing a 360 [Re: scrag] #743250
07/08/10 01:13 AM
07/08/10 01:13 AM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
the starter mounts to the bellhousing so you'd need to fab up something that will put the starter in the correct spot to engage the ring gear on the torque converter.
You could just look around for somebody thats just selling a bellhousing i would think
Re: Testing firing a 360 [Re: chache876] #743251
07/08/10 01:25 AM
07/08/10 01:25 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You could cut the bellhousing off a junk 904 trans I guess. Either that or if you have a bellhousing/flywheel from a manual trans.
