Re: 80 psi on stand with a drill!! [Re: SB412DUSTER] #743138
07/08/10 11:29 AM
07/08/10 11:29 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Since the cam turns half of what the crank does wouldn't the drill be turning the oil pump faster that the engine at idle?
Most our drills spin at 1800/2400 RPM and most cars idle at 900/1000 RPM.80 PSI on a drill is not a issue.If it was a lot less,I would be looking for a problem.
Re: 80 psi on stand with a drill!! [Re: B G Racing] #743139
07/08/10 03:08 PM
07/08/10 03:08 PM
Az
Crizila Offline
Crizila  Offline
Az
80 PSI is normal for priming as all moving parts in the engine are static and no loss of pressure will be caused by dumping by the moving parts.With 80psi cold you usually see 40/50psi at hot idle and 70/80 psi at higher rpms hot if that is the pumps max setting.With most pumps we see max pump pressure cold at higher rpms around 90/100 and settle down when warmed up to 70/80 psi.
- my exact #'S with my 408 and a Melling HV pump.
Fastest 300
Re: 80 psi on stand with a drill!! [Re: Crizila] #743140
07/08/10 04:02 PM
07/08/10 04:02 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
your mint, run it!!!
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: 80 psi on stand with a drill!! [Re: 68 HEMI GTS] #743141
07/08/10 04:09 PM
07/08/10 04:09 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
a lot depnds on your drill too. I use a 1/2 drive DeWalt and on high speed it's 2400. So it's 4800 engine speed and it's usually about 20psi higher turning the engine by hand to oil the top end on the stand than once it's running on the stand. I think you're fine.
Re: 80 psi on stand with a drill!! [Re: moper] #743142
07/08/10 04:25 PM
07/08/10 04:25 PM
Finally a HUSKER again
Moparnut426 Offline OP
I know my snap on drill is at least 2400 rpm.
I feel better now.
Kasey
Re: 80 psi on stand with a drill!! [Re: Moparnut426] #743143
07/09/10 02:06 AM
07/09/10 02:06 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
My 1/2 inch drill would not even spin 250 rpms once the oil pump pressured up. Spinning the drill with out the primer rod, it spins fast of course, but once the pump got pressure up, it just boggs my drill way down. At any rate, my new 499 on the floor, hooked to the trans, spinning the engine over with the starter hooked up and plugs out, it was 85 psi on the gauge. Once I started the engine up in the car, and broke it in, it was 75 psi hot at 2k and 45 at 850 rpms. It goes to 85 psi at 6k. I just run straight valvoline vr1 30w. I was considering putting a stock pump on. I installed an HV since I had an 8 qt pan and roller rockers with a solid cam. I feel it is too much pressure at the higher rpms. I street drive this engine
Re: 80 psi on stand with a drill!! [Re: Mopar-Al] #743144
07/09/10 05:17 AM
07/09/10 05:17 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
I got 80 with a battry drill but when the engine is at running temp I expect I probly wont see more than 50 or 60
