Re: convertible top problem
[Re: bobbyb]
#743076
07/07/10 09:14 PM
07/07/10 09:14 PM
Posts: 366 San Gabriel, CA 91775
rexus31
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
[Re: bobbyb]
#743077
07/07/10 09:17 PM
07/07/10 09:17 PM
Posts: 1,389 Asheboro NC
mopowertim
super gas
super gas
Asheboro NC
Either no power to the pump or no hydraulic pressure out of the pump check fuses, relays, switch- is there power at the pump- if so- is the pump running? If it is- the fluid isnt making to the cylinders, or the cylinders are leaking., You can manually raise and lower the top.
If you can't outrun it-Outlaw it! The King
