wondering if anyone has installed a hyd. roller in there big block and had problems with getting info from manufacturers on proper install's of these? I have a howards cam W/lunati lifters,nobody can tell me how to set the lash....can any help with this set up? They are noisy when at idle in neutral,and when i put the car in gear they seem to almost quiet up completely!!???? The rockers were set at 0 valve lash then tightened 1/2 turn. They sound similar to mechanical lifters, not like hydraulic flat tappet lifters. Was not sure if this was normal or if they should be tightened slightly more or if other problem and should remove and return. Lunati says to return and they will check, but hate to do that if not needed.
