Torsion bar adjustment effects on REAR height #74171
06/15/08 08:30 PM
06/15/08 08:30 PM
Kirkland, Washington
Pacnorthcuda Offline OP
Suppose: You increase drivers side torsion adjustment (raise driver's front end), What is the effect on the rear? (which side will ride higher or lower?) I know the effect on the rear is slight, but there must be some effect right?
Re: Torsion bar adjustment effects on REAR height [Re: Pacnorthcuda] #74172
06/15/08 09:00 PM
06/15/08 09:00 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
It would affect the opposite corner . One goes up, the other goes down
Re: Torsion bar adjustment effects on REAR height [Re: VanishPt] #74173
06/16/08 02:58 PM
06/16/08 02:58 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
All sides move a bit, but the opposite moves the most. Raise front left, and the rear left and front right move up a bit, but the rear right would indeed move down. I tell people this every time someone complains about new leafs sitting crooked and they never believe me until they finally try it.
