Caster Measurement Formula??
#741644
07/06/10 11:31 AM
07/06/10 11:31 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I am trying to align a car and made a Camber fixture that attaches to my wheel rim with a precision ground spot for a digital angle finder.
With this, camber is an easy thing to measure as you could imagine but I want to use it to measure caster too.
While most info online talks about bubble gauges with a caster bubble I can only find bits and pieces of info about the formula used to arrive at a caster number when measuring camber at certain steering angles.
From what I found, I think the proper way is to turn the wheel one way to 20* and measure its camber. Then turn the other direction, also 20* and take another measurement. One direction should read pos camber, the other, negative. Add those two numbers together and then multiply the result by 1.5.
Does this sound right?
Also, with a MacPhearson strut front suspension, isn't the rearward angle of body of the strut the caster angle?
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Caster Measurement Formula??
[Re: CJK440]
#741646
07/06/10 08:11 PM
07/06/10 08:11 PM
Posts: 9,312 SoCal
68HemiB
SoCal
The professional alignment mechanic (as I was in a former life) has not the time for doing needless math when the spirits level for caster does all the work for you. It is a correct statement that one interpolates the caster from a camber change while turning the wheel through 40 degrees. You turn the table 20 degrees in, rotate the gauge to level it side-to-side, then turn the thumbscrew to center the caster bubble. Then turn the table to 20 degrees out, rotate the gauge to level it side-to-side, and read the caster bubble.
I can't help you with the 1.5 times thing, because, as you can see from above, it's a snap with the proper tools. Nobody earning a living is gonna take the time.
As for the theory of caster, although it might matter on how it gets adjusted (or IF it's adjustable at all), the nature of the front suspension matters not. There is always an axis around which the front wheels steer. If there are a pair of ball joints, it's the imaginary line that passes through the center of the upper and lower ball joints. If it's a strut, it's the imaginary line that passes through the center of the upper plate [where the strut rotates] and the lower ball joint. If it's a kingpin, it's the imaginary line through the center of the kingpin. If this imaginary line intersects the ground FORWARD of a vertical centerline through the spindle, that is positive caster. If it intersects the ground rearward of the spindle centerline, that's negative caster. Some people mistakenly oversimplify and visualize the imaginary line tilting BACK for positive and FORWARD for negative caster. In the vast majority of automotive applications, that works, but it is technically the point at which the imaginary line intersects the ground. The "casters" on your rollaway or shopping cart "seek" positive caster as the wheel trails behind the pivot point. That pivot point intersects the ground FORWARD of the vertical centerline of the wheel's spindle, and it has nothing to do with the "tilt" of anything.
Back to the 1.5 thing, it might be easier (and more accurate) to obtain an inexpensive alignment gauge. Otherwise, sorry I can't help there, and good luck.
Down to just a blue car now.
[Re: JeffC]
#741648
07/06/10 10:07 PM
07/06/10 10:07 PM
CJK440
Ansonia, CT
I understand the concept of caster and also know that more expensive gauges will do the math. Just trying to do it on the cheap plus understand the science behind it. I don't mind taking the 10 seconds to punch the numbers in a calculator. The guys who made the caster gauges needed to know the math, I was just wondering if anybody on here knew what the formula was. Turns out with some more searching I found my answer. It is indeed Camber change from 20 to 20 degrees multiplied by 1.5. Here are instructions from a camber gauge manufacturer who explains how to arrive at caster using it. If you are interested, skip to page 9. http://www.solotime.info/dotnetnuke/Portals/0/content/011073_smartcamber_manual.pdfIn my particular case I was doubting my higher than expected results, however turns out some aftermarket parts allow for more caster than stock, hence my numbers.
[Re: nixie33x]
#2901517
03/22/21 09:42 AM
03/22/21 09:42 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
The formula is:
caster (deg) = (180 / 3.1415) * [(camber1 - camber2) / (turnangle1 - turnangle2)]
For a 40 deg change in turn angle,
caster = (180 / 3.14) * (camber1-camber2) / 40 = 1.43 * (camber1-camber2)
1.43 is sometimes rounded up to 1.5.
The formula is derived in the following publication. A number of assumptions are made to make the formula simple but still reasonably accurate.
Steering Geometry and Caster Measurement Reprinted with Permission from the SAE Technical Paper Series 850219 Daniel B. January Hunter Engineering Company Bridgeton, Missouri
pdf file:
http://www.disco3.co.uk/gallery/albums/userpics/24543/steering-geometry-and-caster-measurement%5B1%5D.pdf
Thank you!
