More problems...99 Durango.
I've done a bit of online searching and it would seem this may be a common problem.Anyone else here had to deal with this on these era trucks?
Started off with fuel gauge not working..no big deal right? Next to die was the speedo and tach.It went from not wanting to start and having to fiddle with the key to now just not starting at all with a no bus signal on the odometer display.I have just replaced the crank sensor and disconnected battery overnight to hopefully reset error codes but nothing has changed.
Is an expensive PCM replacement the only thing that will work?
(Aside from what would be my first choice,getting rid of all the computer garbage on this truck...I know intakes and carbs are available,is it possible to 'de-computerize' a '99 5.2 magnum motor? I know it is a good engine but this computer nonsense is about to get the best of me and have the whole truck junkyard bound.)
