Early Upshift Problem #741591
07/06/10 11:13 AM
07/06/10 11:13 AM
MI
Jerseyboy Offline OP
MI
I'm having an issue with my car upshifting early at WOT in Drive. I have a Lokar kickdown cable setup on the car, adjusted to be at the end of travel at WOT and the car still short shifts. Is there an adjustment I can make internal to the trans to fix this? The car is new to me and hasn't been on the road prior to my ownership so I'm not sure what is inside the trans. IT bangs the shift when it does upshift but it just shifts too early. Is there anything I can adjust to help it rev out a bit more?
Re: Early Upshift Problem [Re: Jerseyboy] #741592
07/06/10 11:42 AM
07/06/10 11:42 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It may be the valve body or linkage with the lokar cable setup. When I got Lokar kickdown setup, the outer cable sheath was too long to where I did not get full movement of the kickdown lever. So I would double check the Lokar kickdown first.
If that is good, check the valve body throttle pressure valve is assembled and adjusted correctly.
Re: Early Upshift Problem [Re: 451Mopar] #741593
07/06/10 02:39 PM
07/06/10 02:39 PM
MI
MI
Is there an article/post I can read up on the Throttle pressure vavle adjustment? Thanks for the help!
Re: Early Upshift Problem [Re: Jerseyboy] #741594
07/06/10 03:12 PM
07/06/10 03:12 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What RPM is it upshifting at?
Re: Early Upshift Problem [Re: DaytonaTurbo] #741595
07/06/10 04:31 PM
07/06/10 04:31 PM
MI
MI
Unfortunately I don't have a tach. It feels like it's about 4500-5k, just after I feel the secondaries come in (still need to dial in the AVS spring).
Re: Early Upshift Problem [Re: Jerseyboy] #741596
07/06/10 05:37 PM
07/06/10 05:37 PM
Manitoba, Canada
Manitoba, Canada
If it is in the 4.5-5k range, then there's nothing wrong with your setup. Stock these transmissions were not setup to wind out that high. Want to go higher without manually shifting it? Knock up cope racing trans for an aftermarket governor to get the rpm you desire.
