Re: challenger 6 speed in street rod, shifter driveshaft? [Re: OzHemi] #741574
08/11/10 06:09 PM
08/11/10 06:09 PM
W. Bloomfield, MI
71340vert Offline
71340vert  Offline
W. Bloomfield, MI
Shaftmasters
1668 John A Papalas Dr.
Lincoln Park, MI 48146
313-383-6347
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741575
08/12/10 10:04 AM
08/12/10 10:04 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
FWIW the newer mustangs (seen it on manual trans cars don't know about auto) use a flange on the transmission and a driveshaft with a slip spline in the middle. Maybe that stuff would work for you.
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: 446acuda] #741576
08/20/10 12:45 AM
08/20/10 12:45 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i called shaftmasters and they said they can make me a driveshaft witht the slip built in . it will be aluminum and have an adapter to bolt to the flange. i need to send the flange and they said it will be about $650. so i canceled my order for the factory challenger driveshaft since it has been about 2 weeks and hasnt came in yet anyway. it was going to be $380 plus the price to have a shop rework it to work in my car.
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741577
08/20/10 01:14 PM
08/20/10 01:14 PM
W. Bloomfield, MI
71340vert Offline
71340vert  Offline
W. Bloomfield, MI
I can bring in a flange for you for measurement purposes since I'm going to have them do mine anyways, then I'll get a chance to see the finished driveshaft before they send it out to you. Let me know if you want me to do this for you.
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: 71340vert] #741578
08/22/10 12:29 AM
08/22/10 12:29 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
that would be grear, it would save me shipping the flange to them. Is your flange from a 6 speed?
you might even get a better deal if you tell them you need one at the same time and they can make both parts at once on the CNC machine.
