challenger 6 speed in street rod, shifter driveshaft?
#741554
07/06/10 10:35 AM
07/06/10 10:35 AM
Posts: 1,349 warfordsburg, PA
dirt
warfordsburg, PA
just got in a 6 speed from a new challenger. it has a funky shifter , just a rod coming out of the back of where the shifter is , it must have some remote shifter set up . the output shaft just has a flange with 3 bolts and no slip yoke. how the do you make it work on a street rod project? is there any way to use a normal shifter and slip yoke? here is a picture
Re: challenger 6 speed in street rod, shifter driveshaft?
[Re: OzHemi]
#741558
07/06/10 04:28 PM
07/06/10 04:28 PM
Posts: 387 Almont, MI.
gdemon
Almont, MI.
Here is a pic from a 68 cuda conversion. From For A bodys Only.
69 Barracuda
70 Cuda
70 Cuda
70 Cuda Conv.
70 T/A Challenger
70 Sport Fury GT
71 Demon 5.7 Hemi
72 Demon
[Re: gdemon]
#741560
07/06/10 06:49 PM
07/06/10 06:49 PM
dirt
warfordsburg, PA
thanks, that looks like it would work. is it a 4 wheel drive driveshaft?
i was looking on that forum but didnt find that thread. how do you find it?
[Re: dirt]
#741564
07/06/10 08:40 PM
07/06/10 08:40 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
That's another one of those parts engineered by Merciless Bends and dropped on Chrysler. Meet the Mercedes flex disc. Perhaps you can nab a drive shaft and swap to a rear yoke after you cut it down.
[Re: dirt]
#741567
07/15/10 10:45 AM
07/15/10 10:45 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Wonder if an F body one would be any closer..I can take a pic of mine for you if it would help at all.. Found a pic from a little while ago on my project that shows it..looks like the shifter plate bolts are abit further apart than on yours. Maybe see what the Ford ones look like too?
[Re: dirt]
#741570
08/06/10 12:37 PM
08/06/10 12:37 PM
OzHemi
Garden Grove, CA
I cant find anyone who can get the piece to attach to the flange on the ind of the transmission. everyone is telling me to get the original driveshaft and try to modify it. does anyone know if there is something available to bolt up th the flange or will i have to track down a factory driveshaft?
It looks the same (or very similar) to a Cadillac CTS-V version, maybe grab a used driveshaft front half out of one of those for the flange setup?
If not, in doing a very fast search around, looks like changing the extension housing and output shaft to F body is what some of the GM people are doing to use that trans in 'normal' stuff
