Page 2 of 3 1 2 3
Re: '72 Challenger Project [Re: rhamson] #741475
07/17/10 03:21 PM
07/17/10 03:21 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
What is going on under this paint? I wonder.
Re: '72 Challenger Project [Re: rhamson] #741476
07/23/10 09:12 AM
07/23/10 09:12 AM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
There is a problem with closing the hood with my '72 Challenger where the hood stays up on on the right side and needs to be pressed down to make it sit right. I know the hood should get adjusted to a certain extent but upon closer look there is a difference between the two hinges where they don't mirror each other.
The right hinge has a longer plate connecting the upper and lower arms that mesh together with teeth. The left plate measures about 3-1/8" long while the right one measures 4". Why the difference and is there an explanation.
Re: '72 Challenger Project [Re: rhamson] #741477
07/23/10 09:13 AM
07/23/10 09:13 AM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Here is the right.
Re: '72 Challenger Project [Re: rhamson] #741478
07/23/10 09:15 AM
07/23/10 09:15 AM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
You can also see that the bars do not even face the same direction when the hinge is extended.
Re: '72 Challenger Project [Re: rhamson] #741479
07/23/10 09:51 PM
07/23/10 09:51 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Nice to see more '72 up Mopars being done! I'd love to see even more!!
I love the WHEELS!!
Re: '72 Challenger Project [Re: rhamson] #741480
07/23/10 10:18 PM
07/23/10 10:18 PM
Could be that one of the hinges is not the correct one, just a guess since I am not familure with challys. The rust issues seem to be minor which is good. Keep us posted with the progress and lots of pics.
Re: '72 Challenger Project [Re: rhamson] #741481
09/20/10 09:58 AM
09/20/10 09:58 AM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Finally able to work on the car since building and getting the car on the rotisserie. Just stripping paint and undercoating. Since this was an Arizona car there is only undercoating in the wheelwells. This car is going to be a driver but I want to get all the rust out first so it won't bite me in the a#* later on. Beginning to think about an undercoating for the car. I thought I would prime it with a good gripping primer and then use Rust-olem before I apply an undercoater. Any suggestions as to what is a good undercoater I could apply over the Rust-oleum?
Re: '72 Challenger Project [Re: rhamson] #741482
09/20/10 10:01 AM
09/20/10 10:01 AM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Here is one of those things that burns my butt. The whole car was finish painted with rust bubbles and holes. This was done by a professional shop. This is why I don't trust the bodywork to continue the build when this kind of stuff lurks under the paint.
If you buy a car make sure you invest in one of the paint thickness gauges. It will alert you to exsessive body filler and repaints when considering a project. I did and knew I would find stuff like this on the rear wheelwell lip. Even knowing it still burns my butt.
Re: '72 Challenger Project [Re: rhamson] #741483
10/04/10 10:32 PM
10/04/10 10:32 PM
Long Island Ny
V
varlo Offline
varlo  Offline
V
Long Island Ny
Great work! I to have a 72 and cannot wait to start on it. Keep the pictures coming
Re: '72 Challenger Project [Re: varlo] #741484
10/05/10 05:45 PM
10/05/10 05:45 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Thanks, I really wish I had more time to work on it and post the results as so many others have in here. It really gives me a kick in my butt to quit making excuses and get busy.
I have decided to strip the bottom down to bare metal and spray POR15 to the entire bottom. The car is going to be black and this will just make the whole thing come together and match the bottom to the top.
Keep going with your project!!
Re: '72 Challenger Project [Re: rhamson] #741485
03/30/11 02:50 PM
03/30/11 02:50 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Got to work on some of the problem areas before I committed to the four speed hump and then onto the frame stifening.
Re: '72 Challenger Project [Re: rhamson] #741486
03/30/11 03:41 PM
03/30/11 03:41 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Rough patch from quarter panel skin I had.
Re: '72 Challenger Project [Re: rhamson] #741487
03/30/11 03:43 PM
03/30/11 03:43 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Drivers side rear lip rust.
Re: '72 Challenger Project [Re: rhamson] #741488
03/30/11 03:47 PM
03/30/11 03:47 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Another quarter panel skin patch fix.
Re: '72 Challenger Project [Re: rhamson] #741489
03/30/11 03:52 PM
03/30/11 03:52 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
This is the overlap trunk patch that the former owner fixed.
Re: '72 Challenger Project [Re: rhamson] #741490
03/30/11 03:53 PM
03/30/11 03:53 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
I cut it between the seam and butt welded and leaded it in place.
Re: '72 Challenger Project [Re: rhamson] #741491
03/30/11 03:56 PM
03/30/11 03:56 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
There was a rust hole under the drivers side rear window so I cut a patch panel from the quarter panel skin I had and welded it in at the body lines.
Re: '72 Challenger Project [Re: rhamson] #741492
03/30/11 03:58 PM
03/30/11 03:58 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Sorry, I had only a picture of the hole cut out and where I used POR15 on the inner rocker. Here is the patch.
Re: '72 Challenger Project [Re: rhamson] #741493
03/30/11 04:03 PM
03/30/11 04:03 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
The former owner had done another lip patch on the drivers floor which I felt is a no no when a panel is exposed to the elements the same as the trunk. I cut out between the seams and butt welded the two pieces together. At the front of the patch the new piece he had welded in was so thin and blown apart from the welding I went ahead and welded a new piece in while I was at it. I also made the plunge and installed a four speed hump so I am committed to the manual transmission now. Here is the before.
Re: '72 Challenger Project [Re: rhamson] #741494
03/30/11 04:05 PM
03/30/11 04:05 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Here is the results.
Page 2 of 3 1 2 3
