Re: Carter AVS Help needed
[Re: a12rag]
#740584
07/05/10 11:13 AM
07/05/10 11:13 AM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Also check your advance curve....when going back to the correct 4640SA AVS for my '69 I had a terrible off idle stumble. Originally I had my vac advance locked out on my dizzy when I had my 750 Holley. Turns out I was told AVS's NEED vacuum advance due to their lean idle nature. had my dizzy recurved by Don over at FBO to incorporate back my vacuum advance & problem solved for the most part....still am futzing with choke mechanism but that's a different topic....
1MYTGTX
[Re: dd340]
#740587
07/05/10 05:57 PM
07/05/10 05:57 PM
Posts: 601 Mass
charge70
Mass
I read somewhere that the check ball assy,the one on the feed side into the bowl area can leak back.The shot instead of going to the squirters goes back to the bowl area.Maybe worth looking into. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#740588
07/05/10 10:43 PM
07/05/10 10:43 PM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
If the carb is a recent rebulid, perhaps the accel pump plunger is folded back and not sealing. I've rebuilt two AVS carbs for personal use, using Walker rebuild kits from Larry Isgro Carburetors. They work really well. On both rebuilds, I found it took a lot of time and care to install the leather accel-pump plunger without the leather gasket edge folding back on itself in the accel pump bore.
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: demonH1B]
#740592
07/08/10 06:10 PM
07/08/10 06:10 PM
Posts: 10,220 Someplace you aren't
SomeCarGuy
I fought this last summer and concluded that the bore for the pump was a little out of round or wide in some spot.
It gets better when the car warms up and it swells just a bit. Still get a dry shot every now and then when warm.
I had the top off and worked the plunger by hand at one point. Just no shot for no real reason sometimes. Tried cleaning by soaking, starting fluid, you name it.
I just live with it now. Great carb other than that.
I want my fair share
