Re: Understanding how to use Advance Timing Light
[Re: wh23g3g]
#740429
07/11/10 07:20 PM
07/11/10 07:20 PM
Posts: 153 Georgia
wh23g3g
Georgia
I readjusted the accelerator cable. The gas pedal feels how it should be. Firm. I started it up and it was still running at 600-650RPM. As you can see in the pic I have the curb idle screw all the way in and it doesn't even touch the lever. I moved one of those levers before I adjusted the cable and the curb idle screw barely touched the lever then, so I thought I was ok then. Only to find out it's still too far away when I started it up. I have not messed with the fast idle screw. The 73 manual even says to put 500 miles on the car before adjusting the fast idle. Could it be in too far still? I guess because of the size restrictions the photo is enlarged but hopefully you can see.
[Re: wh23g3g]
#740432
07/11/10 10:24 PM
07/11/10 10:24 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
I can see from your pic that the s link for your accelerator pump is backwards, makes me wonder what else might be out of adjustment. Everything else that you are showing looks normal to me. I'm no expert on the TQ's but I am having to learn mine. Where are the air/fuel screws set at on yours? If they are too far in that will idle you way down. Here is a link, look at the upper left picture. You can click on it to enlarge it. http://oldcarmanualproject.com/manuals/Carbs/Carter/Thermoquad/1972/images/1972TQ_0007_jpg.jpgEDIT; After you get the s link switched around "lightly" seat the air/fuel screws and back them out 2 and 1/2 turns it also looks like your fast idle screw is way to far in also. Back it out some. I suspect that you will have to tinker some to get it right it's the nature of the beast. You are running a spreadbore intake correct?
[Re: Mopar_Country]
#740433
07/11/10 10:39 PM
07/11/10 10:39 PM
Posts: 667 CA
66Dodge
super gas
super gas
CA
