Rebuilding heater/defroster unit of a Challenger
#740161
07/04/10 12:15 PM
07/04/10 12:15 PM
Posts: 263 Switzerland, Europe
Swiss_Robert
Switzerland, Europe
Following all the advices that I've got from this very helpful board, I digged deeper and deeper towards firewall - inside my 1970 Challenger (440-sixpack clone without AC). Today I arrived at the heater/defroster box. Down there everything is in a bad shape. The fan was filled with old leaves and debris and did not move for many years obviously. Radiator leaked. And so on. I found that it is not too easy to get parts for that box. Radiator is easy but a new blower motor or seals or cardboard stuff seems to be rare... Is there someone specialized who sells that kind of stuff?
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: Rebuilding heater/defroster unit of a Challenger
[Re: Swiss_Robert]
#740164
07/04/10 12:27 PM
07/04/10 12:27 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Can someone tell me, why I have this gap between heaterbox and defroster-channels??? What's missing???
Nothing is missing, quality from back in the day.
[Re: Swiss_Robert]
#740169
07/04/10 04:08 PM
07/04/10 04:08 PM
Posts: 12,427 Warren, MI
71TA
Warren, MI
The kits and cardboard WERE rare when I pulled MY 71 Challenger heater box about 6 years ago now. Mine looked like yours. I cleaned it all up and thought I'd just Google a heater box restoration kit. NOT. If I had a Camaro or Moostang I there were some crappy kits available but NOTHING for Mopar. Now I make all the Mopar heater box restoratiion kits in A/C and Non A/C from 63-76. Don't have the 69-7X C bodies though. Funny, many people ask me about that "gap". In fact some have told me I don't know what I'm taking about when I tell them there is NOTHING that goes in that gap PS I just had new clips sets made for the heater boxes too. It's amazing how much is being remade or can be restored by artisans like Jules above!
[Re: 71TA]
#740170
07/04/10 04:34 PM
07/04/10 04:34 PM
Posts: 1,188 imperial mo.
stickman
imperial mo.
You can buy a heater core at rockauto.com
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
[Re: stickman]
#740171
07/04/10 09:14 PM
07/04/10 09:14 PM
Posts: 1,822 Colorado
denfireguy
Colorado
You can but it is not anywhere near the quality of the OEM part. It lacks much of the support of the original. I could see it failing from metal fatigue. I had mine boiled out and pressure checked by a radiator shop. Since it passed the check, I sent the replacement back for a refund. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Swiss_Robert]
#740176
08/03/10 07:11 PM
08/03/10 07:11 PM
Swiss_Robert
Switzerland, Europe
I'd like to report the follow-up. I've got the exciting kit from james fillmore - it's one of the finest i've ever seen: Not only everything fits perfectly but he adds a very helpful documentation. I've got the heater core from summit racing. And I did rebuild the blower motor just with some ellbow grease It's not to difficult - i'll give you some pics:
[Re: Swiss_Robert]
#740177
08/03/10 07:16 PM
08/03/10 07:16 PM
Swiss_Robert
Switzerland, Europe
Uuups: How to start - first brake anything to make it more demanding... (Jim wrote in his documentation: clean it CAREFUL). But it's plastic and can be glued again Then: gave the doors a coat with zync-paint and glued the foam gaskets on as Jim described. Fixed the black plastic hump with pop rivets...
[Re: Swiss_Robert]
#740178
08/03/10 07:19 PM
08/03/10 07:19 PM
Swiss_Robert
Switzerland, Europe
To build in the defroster door is a bit tricky - it's not exactly symmetrical and it took me a while to figure out which turn around it will fit.
[Re: Swiss_Robert]
#740179
08/03/10 07:23 PM
08/03/10 07:23 PM
Swiss_Robert
Switzerland, Europe
So this is the backside of the box with everything attached including the new cardboard (also from Jim) and the new clips (dito). Jim also includes the gasket to the firewall - in 2 versions...
[Re: Swiss_Robert]
#740180
08/03/10 07:27 PM
08/03/10 07:27 PM
Swiss_Robert
Switzerland, Europe
Now the front half - and the caulk- thing. Btw: to remove the air-vent door from this half it's necessary to drill out 2 rivets it's fixed with. Can be refixed with pop rivets...
