Proper/Correct tire size, 67 R/T? #73969
06/15/08 09:35 AM
06/15/08 09:35 AM
Morningside
AdventurerSport Offline OP
waaaay out there in left field
Morningside
How do I find out the correct tire size for my '67 R/T? Is there a chart somewhere?
I need to know so that I can order the correct speedo gear for my trans, but I'm not even sure where to start..?
I'm trying to build it to stock as closely as reasonably possible...what tire size would it have come with originally? What tire size(s) are you guys running on '66-67 B bodies? What looks good but is reasonably close?
Thanks!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: Proper/Correct tire size, 67 R/T? [Re: AdventurerSport] #73970
06/15/08 11:01 AM
06/15/08 11:01 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
The 7.75x14 red wall was standard with the 7.75 white wall optional. The equivelent is an F70 series or 215/70 metric. I bought the Diamond back F70 red wall radials for my 69 R/T.
Pinion depends on gears and tranny.
29 tooth for automatic with 8.75 and 2.94 gears
32 tooth for automatics with 8.75 and 3.23
35 tooth for four speeds and Danas with 3.54
Re: Proper/Correct tire size, 67 R/T? [Re: 69CoronetRT] #73971
06/15/08 11:22 AM
06/15/08 11:22 AM
Morningside
Morningside
Thank you very much! That's JUST what I needed to know!
I have an auto/3.23 car, thank you very much!
JS
Re: Proper/Correct tire size, 67 R/T? [Re: AdventurerSport] #73972
06/15/08 01:12 PM
06/15/08 01:12 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I agree 7.75X14, these are 225X70X14.
Sheldon
