piston rings - dot to the top? #739134
07/02/10 10:29 PM
07/02/10 10:29 PM
Space Station #5
471Magnum Offline OP
Space Station #5
Putting together a short block for a friend. He gave me the piston rings for it (Sealed Power) with no instructions.
Which way does the dot go? Up or down? Pretty sure it's up, but I want to be absolutely certain.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: piston rings - dot to the top? [Re: 471Magnum] #739135
07/02/10 11:13 PM
07/02/10 11:13 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
tops rings make sure bevel down dont care were dot is
MOPAR OR NO CAR
Re: piston rings - dot to the top? [Re: 471Magnum] #739136
07/03/10 09:40 AM
07/03/10 09:40 AM
Southwest
way2fast Offline
way2fast  Offline
Southwest
instructions say dot to the top, just put mine in. I used the sealed power moly rings.
Go Fast and Swerve!
Re: piston rings - dot to the top? [Re: hemigod426] #739137
07/03/10 05:49 PM
07/03/10 05:49 PM
thats not correct. top ring the bevel goes up, 2nd ring the bevel goes down.
Re: piston rings - dot to the top? [Re: hemigod426] #739138
07/03/10 06:15 PM
07/03/10 06:15 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
That is not correct.
