727 transmission slipping in reverse question
#73887
06/15/08 01:11 AM
06/15/08 01:11 AM
My 727 trans is slipping in reverse. Forward gears are all fine. Is there an adjustment I can make under the pan or do I need to remove it and dig deeper into it....Thanx Guys!
Re: 727 transmission slipping in reverse question
#73888
06/15/08 01:28 AM
06/15/08 01:28 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
check rear band and rear servo....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#73889
06/15/08 01:30 AM
06/15/08 01:30 AM
Where is the rear band and servo? Are they accesible under the pan?
#73890
06/15/08 01:31 AM
06/15/08 01:31 AM
70AARcuda
las vegas
yes..you must remove the pan...
Tony
[Re: 70AARcuda]
#73891
06/15/08 01:32 AM
06/15/08 01:32 AM
