1969 B Body Hemi 4 Speed Trans Mount #73858
06/14/08 11:08 PM
06/14/08 11:08 PM
PA
dodgeman316 Offline OP
PA
I asked this question over in the Restoration forum as well.
In the tech archives there is a specific part number for the 1969 B Body Hemi 4 speed manual trans mount - 2660673.
Anyone know what the difference is between this mount and the 2533145 mount?
Can the 2533145 mount be used in place of 2660673?
Re: 1969 B Body Hemi 4 Speed Trans Mount [Re: dodgeman316] #73859
06/15/08 12:30 PM
06/15/08 12:30 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I thought (based on what I had read here when this topic came up previously) that Hemi cars used a different colored rubber (yellow, maybe?) and a higher density rubber, hence the different part number.
As long as they're the same type (spool?), they should interchange.
Re: 1969 B Body Hemi 4 Speed Trans Mount [Re: In_The_Pink] #73860
06/16/08 09:26 AM
06/16/08 09:26 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
69 didn't use a spool mount .
Re: 1969 B Body Hemi 4 Speed Trans Mount [Re: dodgeman316] #73861
06/16/08 01:23 PM
06/16/08 01:23 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
No spool mount in 68 or 69. They used a block type mount that dropped into a pocket on the front of the cross member for automatics, or in the middle of the crossmember on manual trasnmission cars. There is a difference of cross members.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
