which intake gasket? #73812
06/14/08 09:50 PM
06/14/08 09:50 PM
Id
mopeman Offline OP
mopeman  Offline OP
Id
Ok, so I'm ready to install my eddy performer intake on my rebuilt truck 360 and there are two types of gaskets for it. One is steel and the other is a composite/paper. I checked to make sure and they both fit, I thought one might be for a magnum. The old ones look like the composite/paper. Also, the block does not have the dowels for the front and rear end gaskets, am I ok to install them or should I make some to keep the gaskets in place?
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: which intake gasket? [Re: mopeman] #73813
06/14/08 09:52 PM
06/14/08 09:52 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I wouldn't use the steel on anything. Only use the composite.If you are using an after market intake the dowels cannot be used. They hold the intake up out of place so leave them out.
Re: which intake gasket? [Re: MoparforLife] #73814
06/14/08 09:57 PM
06/14/08 09:57 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Its also best not to use the end gaskets. Use a thick bead of sealer on there instead.
