Under hood bracing 64 plymouth Max wedge #737035
06/29/10 09:55 PM
06/29/10 09:55 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
I am building a 64 Plymouth Max wedge clone & I was wondering if there is enough clearance for the stock air cleaners without cutting the underhood bracing Car has stock 64 K member 440 bottom end stock intake carbs & air cleaners no hood scoop.
Sal
Re: Under hood bracing 64 plymouth Max wedge [Re: gts1] #737036
07/02/10 02:29 PM
07/02/10 02:29 PM
oregon
ramcharger1964 Offline
oregon
as long as you use a orig or repro craooram manifold you will be fine. If you use one of the Indy manifolds (2x4) you will run out of room!
Hell B!tch Racing Co.
Re: Under hood bracing 64 plymouth Max wedge [Re: ramcharger1964] #737037
07/02/10 02:29 PM
07/02/10 02:29 PM
oregon
oregon
Sorry - meant to say CROSSRAM above...
