4 spd hump placement-62-65 b-body
#73655
06/14/08 06:33 PM
06/14/08 06:33 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
I haven't been able to find the archived post concerning the hump placement.Found late B and E body.Need it for 62-65 B-body.Thanks!
Leave the gun.......take the Cannoli's....Mike
Re: 4 spd hump placement-62-65 b-body
[Re: mike s]
#73660
06/15/08 12:21 PM
06/15/08 12:21 PM
Posts: 5,044 At a gas station near you
badblack68
Yes I have the steel re-pop hump.Seems a bit wide for the tunnel in some spots. No console bench seat.Did you remove the rubber floor plug and weld a patch in or just seal over it? Thanks for the help.
I removed the plastic plug and welded the tang right over the hole. Before I welded in the hump I traced all around it with a piece of white chalk. Then I removed the hump and cut 1/2" inside of the white line all around. It makes quite a big hole in your floor but your going to need all that room under the car for your shifter box, linkage, and the trans itself. I put an 18 spline hemi 4 speed in my 64. I also seam sealed both the inside and outside after welding the hump. I then painted both sides.
[Re: badblack68]
#73661
06/15/08 05:16 PM
06/15/08 05:16 PM
mike s
Mi,U.S.A.
Thanks again guys! Great info.
