1970 floor shift assembly #736267
06/28/10 11:00 PM
06/28/10 11:00 PM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Guys I need the bracket that bolts to the trans, along with the bushing that supports the vertical shaft that goes thru the floor. I can't make out the part no in this drawing but it's the bracket with two studs that go thru the ear on the trans case.
Are these available from anybody as repros or do I scrounge ebay and swaps to get them?
Re: 1970 floor shift assembly [Re: Quikshft] #736268
06/28/10 11:31 PM
06/28/10 11:31 PM
PA USA
ScatPakWarehouse Offline
Good Guy Alert
Good Guy Alert
PA USA
I think i have a spare PM your address & i'll check my stash in a few if i have it can get it out to you .. Chuck
Re: 1970 floor shift assembly [Re: Quikshft] #736269
06/29/10 04:47 PM
06/29/10 04:47 PM
PA USA
Good Guy Alert
Good Guy Alert
PA USA
Going out wed am ... your mailbox is full
Re: 1970 floor shift assembly [Re: ScatPakWarehouse] #736270
06/30/10 01:33 AM
06/30/10 01:33 AM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Mail box trimmed.
