a/c compressor wiring #73607
06/14/08 04:21 PM
06/14/08 04:21 PM
Andrewh Offline OP
Andrewh  Offline OP
Again, dropping a 2000 durango motor into a 65 coronet.
The durango has 2 wires coming off the compressor, I only have one.
can't really understand the diagram to figure out where the other line goes, or is it just a computer controled ground?
Re: a/c compressor wiring [Re: Andrewh] #73608
06/14/08 06:47 PM
06/14/08 06:47 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Looks to me like the DK BLUE/BLK wire is what sends power to the A/C comp. clutch, and the PK (pink?) wire is the ground for the A/C comp. clutch.
Re: a/c compressor wiring [Re: In_The_Pink] #73609
06/14/08 06:56 PM
06/14/08 06:56 PM
Andrewh Offline OP
Andrewh  Offline OP
Thanks. I will try it that way and see if it works.
