Re: K&N air filters
[Re: Haibach Boys]
#734813
06/28/10 09:19 PM
06/28/10 09:19 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I've been waiting to see this "gasser" for years now
Do I have to come out there and take the pics myself ![](/ubbthreads/images/graemlins/rant.gif)
![](http://i16.photobucket.com/albums/b7/JohnnyCharger1968/Emoticons/ThisThreadIsWorthlessWithoutPics.gif)
As for the lame 4 door ![](/ubbthreads/images/graemlins/shock.gif)
Do I have to tell you again ![](/ubbthreads/images/graemlins/laugh2.gif)
Yeah I know, I'm not really a fan of 4 doors (or coronets for that matter) but you've built a killer ride there.
Still think you need to paint half the rear wheels like they did back in the day. ![](/ubbthreads/images/graemlins/punkrocka.gif)
Re: K&N air filters
[Re: Haibach Boys]
#734820
06/28/10 09:43 PM
06/28/10 09:43 PM
WILD BILL
BROOK PARK, OH
Aren't you glad I had the TALL jack stands ![](http://i300.photobucket.com/albums/nn35/wildracing/Smilies/roflmao.gif)
Thanks again for all your help ![](/ubbthreads/images/graemlins/bow.gif)
Re: K&N air filters
[Re: Haibach Boys]
#734822
06/28/10 09:47 PM
06/28/10 09:47 PM
WILD BILL
BROOK PARK, OH
old one....
Anything recent?
I know you've worked on since right?
Re: K&N air filters
[Re: scratchnfotraction]
#734824
06/29/10 06:15 AM
06/29/10 06:15 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
you cant see thru mine right now,thats for sure ![](/ubbthreads/images/graemlins/scope.gif)
now if you let it dry out I could see it not filtering very well
the oil is not gonna let any dust thru if it is kept properly oiled
read the box on theory of operation on how it works,it is to be oiled more often if it is in a real dusty service area and heat will dry it out
so it does need to be serviced from time to time
I encourage anyone running a K&N air filter to get a Used Oil Analysis done on your next oil change. If your air filter is not doing it’s job, you’ll see it in the motor oil.
Below, the comments of Certified Lubrication Specialist, George Morrison regarding air filtration.
Introduction: The late George Morrison, was a Certified Lubrication Specialist by the Society of Trobologists and Lubrication Engineers as well as the founder and CEO of AV Lubricants, one of the largest Exxon/Mobil distributors in the United States. During his 35 years in the lubricant industry, He worked with such industries as Aviation and Coal Mining assisting with their specific lubricant needs in which hundreds of Used Oil Analysis reports went through his hands a week. As a result, Mr. Morrison was an expert in lubricant and lubricant filtration.
Quotes by Mr. Morrison:
"From a lube engineer's perspective that looks at a hundred or so oil analysis results a day, I would highly recommend you or anyone running a K&N or other aftermarket air filter do an engine oil analysis to determine that the filter is indeed doing its job. I can easily spot a K&N equipped vehicle oil analysis results as in 90% of cases the filter keeps out bricks and birds very effectively but little else. The #1 cause of reduced engine life is dirt. The #1 engine oil alert I look at is dirt. One teaspoon of dirt will destroy a large V-16 CAT engine.. i.e. we need to make sure we have the best filter media, tightest induction system possible to ensure maximum engine life. If you look at a K&N filter you can see through the medium very easily. Supposedly the 'tackifier' grabs the incoming dirt particles. Visualize a dirt particle approaching the filter medium at 100+ MPH: there is NO oil, no tackifier that is going to reach out and capture that particle. Filter face impact velocity is just too great."
"Regarding the "easy 10 hp increase", I would be wary of the claim. A recent VW TDI dyno day revealed that the highest horsepower developed at the rear wheels was for a TDI equipped a paper, OEM equipped VW vs. the foam/paper/K&N, snorkled VW's."
"If you have single digit silicon and low wear metals with your oil analysis results, you are about as good as it gets! That is a general target for dirt: i.e. single digits. If you have this with spectro, you have excellent air filtration with no induction leaks. As for recommendations, I suggest name brand/OEM paper. If a person wants to try another, do an oil analysis with quality paper, then another oil analysis, with particle count, for the aftermarket. This will give a complete picture of exactly how the aftermarket is doing."
Summary: As stated above, Used Oil Analysis is the real world test which proves OR disproves the as advertised filter efficiency claims.
Source cited: Click HERE ![](/ubbthreads/images/graemlins/wiink.gif)
Re: K&N air filters
[Re: OrangeProwler]
#734827
06/29/10 07:19 AM
06/29/10 07:19 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
The KN filter was originally invented in 1964 for SCCA weekend track racing by Ken Johnson and Norm McDonald, where many were previously running without any air filter protecting the engine, and the oiled cotton gauze was a slightly better choice... the lesser of two evils. http://findarticles.com/p/articles/mi_qa4078/is_200402/ai_n9350913/Ken and Norm later sold out for a small fortune in the 1990s. When totally new and clean, but without excessive oil, the KN may have about 2 to 3 inches of water restriction less, but that it out of about atmosphere all around us total pressure of 404 inches of water pressure. The Spicer web report previously posted above has good graphs showing this, but also shows how quickly the KN clogs up, and it lesser particle trapping efficiency. For daily driving use shouldn't the restriction of a filter be measured out at 5000 to 10000 miles? Shouldn't you be more interested in the 'real world' restriction during most of the time your engine is 'feeling it' and not just when new?
Re: K&N air filters
[Re: 360view]
#734829
06/29/10 05:02 PM
06/29/10 05:02 PM
CompSyn
Pacific NW USA
Thanks for the info. Great article, great information!
Fortunately for K&N, people still love and use them despite the increasing mountain of data against them. ![](/ubbthreads/images/graemlins/shruggy.gif)
But hey! Cutting edge 1960s air filter technology on your 1960s Mopar, why not!?!
