Rust in torsion bar mount? Stay away?
#733361
06/25/10 01:24 PM
06/25/10 01:24 PM
Posts: 254 Vista, CA
71Chip
Vista, CA
I'm looking at an otherwise clean roadrunner to buy, that has rust in the torsion bar mount underneath the driver's side floor pan. The driver's side front floor also needs replacing obviously. I'm guessing water sat in this spot for a long time. Other than that, the car is 99% rust free.
I'm just concerned that to repair the torsion bar mount the entire thing would need to be removed and replaced?
71 Challenger
Re: Rust in torsion bar mount? Stay away?
[Re: 71Chip]
#733365
06/26/10 02:08 AM
06/26/10 02:08 AM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
you can replace part of the T-bar crossmember. since you'll be replacing part of the floor that should make it easier.
[Re: 71Chip]
#733367
06/26/10 09:10 AM
06/26/10 09:10 AM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
If going with a full front floor replacement, then swapping out torsion bar cross member is fairly easy. It is possible that there will be other rust, so look carefully.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: ahy]
#733369
06/26/10 03:44 PM
06/26/10 03:44 PM
nomore65BelvJim
Auto Rust Technicians sells the repair parts for the T bar mount. Its not a real hard repair.
With both the tortion bar and transmission mount stresses put upon it I would not touch a A.R.T. cap for a T-bar crossmember. Do it right and replace it with a good used factory piece.
[Re: nomore65BelvJim]
#733370
06/26/10 04:48 PM
06/26/10 04:48 PM
Posts: 7,664 IN
ahy
IN
I believe the ART parts can be used as caps or complete replacements after removing the original. For complete replacement, the actual T bar mounts would be removed from the original and welded into the ART piece. From memory they ara as thick as or thicker than original. It would be worth a call to them to double check.
[Re: ahy]
#733371
06/26/10 05:01 PM
06/26/10 05:01 PM
nomore65BelvJim
if it is a 70 B ART doesnt even make a full T bar crossmember, only the horizontal side pieces with NO tabs to attach it to the rocker or flanges to attach the floor pan to. And they are called SAFE-T-CAPS for a reason, they are frame caps not replacement parts. Even if they did make a full piece why would anyone in their right mind replace the whole thing with a bent steel cap for more money ($249+s&h for the 2 pieces they do make) than a factory original stamped steel replacement could be had for? yeah, that looks real sturdy .
[Re: DaytonaTurbo]
#733372
06/26/10 09:28 PM
06/26/10 09:28 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
There will be 5x more rust than what is visible once you start tearing into it.
Not necessarily, not in this side of the country. East of the Divide and up your way, yes.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
