common 604/41te fwd trans problems.. #732870
06/24/10 04:57 PM
06/24/10 04:57 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
what are some of the common problems with the 604 trans in a carvan, 2000 yr?
this one hit a pot hole now it seems to just go into net, I found zero codes? running fine before this, or so the customer says..
Re: common 604/41te fwd trans problems.. [Re: Dakota_Don] #732871
06/24/10 05:20 PM
06/24/10 05:20 PM
Alton, IL
Alton, IL
is it possible for the solenoid pack to have gotten damaged and not throw a code?
Re: common 604/41te fwd trans problems.. [Re: Dakota_Don] #732872
06/24/10 05:27 PM
06/24/10 05:27 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Solenoids can fail and not be detected until requested to function.
I was thinking it might be that pack.
- Stu Harmon
Re: common 604/41te fwd trans problems.. [Re: feets] #732873
06/24/10 05:44 PM
06/24/10 05:44 PM
Alton, IL
Alton, IL
ty i hate guessing.. i cant see the trans failing from a bump in the road.. so hopefully thats it.. is there a way to test the sol pack? id hate to but a new/reman one and that not be it..im going to try to clean it out in case its clogged first..any other ideas?
