2002 300M Help #732083
06/23/10 04:09 PM
06/23/10 04:09 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
My son was driving his 02 300M 142000 mi on the hiway car was running fine.He then heard a noise the RPMs went up & the trans appeared to be slipping.He nursed it about a mi to a rest area & I had it towed home.Now if you put it in drive it will move forward but makes grinding noises wont do anything in reverse.The trans fluid is full&the fluid is not burnt at all Any ideas as to what it may be?
Sal
Re: 2002 300M Help [Re: gts1] #732084
06/23/10 04:16 PM
06/23/10 04:16 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Sounds like it may be in limp mode. You can usually get a trans shop to read the codes off of the TCM on those cars at no cost, that should tell you if you have an electrinics issue of a mechanical issue. If it comes to it and you want to swap that trans out you can usually find guys who will rebuild them for around $600.
Re: 2002 300M Help [Re: gts1] #732085
06/23/10 04:36 PM
06/23/10 04:36 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
No reverse tells me it's not in limp mode. It sounds like the tranny failed, especially if it's making ugly noises.
- Stu Harmon
Re: 2002 300M Help [Re: gts1] #732086
06/23/10 05:13 PM
06/23/10 05:13 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I just had this happen to my 04 intrepid and it wasted a planetary setup, the trans has to be gone through completely.
