You guys ever go faster with less gear?
#731280
06/22/10 03:14 PM
06/22/10 03:14 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
In my small block Dart Sport I am running 5.13 gears and a 33" tall tire. It rpms pretty quick in the 1/8th mile and haven't had it run in the 1/4 with the new 422" motor yet. I was kind of thinking about less gear and less tire to reduce mass. Have any of you guys ever switched to less gear and went faster/quicker? Thinking of 4.88's or 4.56's. Normal footbraking e.t.'s are 6.20's at 108mph at 2930lbs.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Post deleted by Defbob
[Re: Jacob Pitt]
#731281
06/22/10 03:19 PM
06/22/10 03:19 PM
Re: You guys ever go faster with less gear?
[Re: Jacob Pitt]
#731283
06/22/10 04:21 PM
06/22/10 04:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats probably a good gear for the 1/8 but its too steep for the 1/4 with a 422".... try the 4.56... you should have enough torque to pull it
[Re: Jacob Pitt]
#731285
06/22/10 05:51 PM
06/22/10 05:51 PM
Posts: 5,894 Florida
Locomotion
I had a 2,800lb Challenger with a ported W-2 360/727. 5.13 and 32" tall tires - 10.22@130+ and forgot if it was 6.40's or 6.50's that I touched a couple of times. 1.37 best 60' footbraking also. It was all the gear it could handle. So 4.56 or 4.88 should work better with your stroker. Also found out that shifting at 7,100 and 6,800 didn't seem to make any difference, so I shifted lower.
[Re: Locomotion]
#731286
06/22/10 09:45 PM
06/22/10 09:45 PM
Jacob Pitt
Mansfield, Tx
Thanks for the info guys. I only run 4.30's in the Challenger but with a big block it has no problem with torque and is much heavier. I think a 4.88 or 4.56 would pick up my mph and help with hot tracks. Just one more thing on my to do list. So good brakes and less gears are on the list.
[Re: Jacob Pitt]
#731287
06/22/10 11:11 PM
06/22/10 11:11 PM
Posts: 1,153 Adrian, Mi
pro6pakRR
mopar addict
mopar addict
Adrian, Mi
My brother's 71 GTX stock 440 6bbl,509 cam,with 4.30 gear's ran 13.20@105 went to 3.55 gear's and car ran 12.88@107 with nothing else changed
[Re: Scamp408]
#731292
06/23/10 09:05 AM
06/23/10 09:05 AM
Posts: 1,178 Indy
FlyFish
Indy
I think it just comes down to the specific combo…FWIW, when I switched from 3:55’s to 4.10’s my car picked up half a second, but that was with a somewhat mild 360 in my 3250lbs car.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: Jacob Pitt]
#731294
06/23/10 12:28 PM
06/23/10 12:28 PM
Posts: 781 MD
HEMI472
MD
You want to be fast, you need wheelspeed, not rpm. A steep gear is usually a lot of noise from engine rpm, but the car is going nowhere. Monte did you ever see a super stock car all of them has steep gears?
[Re: HEMI472]
#731295
06/23/10 12:53 PM
06/23/10 12:53 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Monte
SS,stock and other class cars that are held to limits and specs need to use every way possible to gain every minute advantage and max output. A car with unlimited combos,weight,cubic inches,power adders,with no restrictions are more likely to benifit from less gear.Most bracket cars fall in this catagory(less gear).They would never last winging them with deep gears,where as a class car doesn't have to run hundereds of rounds each season and are heavely maintained after only a few runs.
[Re: HEMI472]
#731296
06/23/10 02:32 PM
06/23/10 02:32 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Monte
As BG said, this is not a stocker, super stocker, pro stocker, or comp car, that has a tiny power window and are trying to ring every ounce out of it. You can't compare class cars with bracket racers. In stock, you have stock bore/stroke motors, with factory heads and carbs running 9s, in heavy cars on a small tire. Most average bracket cars with 500in motors, big tires and link suspensions are lucky to do that and most will be as quick or quicker, with less gear. Its more about the torque converter than anything.
Monte
[Re: Monte_Smith]
#731297
06/24/10 07:11 AM
06/24/10 07:11 AM
B G Racing
Eighty Four, PA
Monte
Monte
X2 Class cars also rely on dead hook which terminates HP and torque,a bracket or quick car likes a little wheelspin and it is controled by proper use of torque application in various methods:gears,converters,launch controls and etc.It's been proven over and over less gear=more MPH=better ET in most cases.Case in point my car started with 5.13 and picked up going to 4.88,in the quest to lessen the RPM at the stripe we switched to 4.56 and the car picked up even more.With the over abundence of HP and torque the Hemi makes we may consider 4.30s.We did this in Ron McCellands Hemi and he dropped from 9.60s to 9.50 with the gear being the only change.
[Re: B G Racing]
#731298
06/24/10 10:38 AM
06/24/10 10:38 AM
Posts: 233 Amarillo, Tx
daithi2
Amarillo, Tx
in my 408 dart i went from 456 to 430. my 60' and 1/8m et's were slower but my 1/4 i picked up 3 tenths and 6mph.
47 Dodge - turbocharged 493"
05 SRT6 - Only 10 second and fastest SRT-6
[Re: can.al]
#731301
06/25/10 10:05 PM
06/25/10 10:05 PM
Posts: 850 Georgetown, TX
sc4579
Georgetown, TX
Jake, sure wish I had that car back. Hell I wish I had the time and money to race at all.
2023 Challenger Scat Pack 1320 2016 Jeep Renegade
