Re: Updated
[Re: gtx6970]
#730800
12/02/10 11:06 PM
12/02/10 11:06 PM
Posts: 21,406 It's a dry heat
gtx6970
It's a dry heat
Spent this morning dis-assembling 1/4 window glass and trim.
The tinted glass had 71-74 trim on it,so I took all of the apart to transfer the 70 only trim that was on the clear glass but needs to be on the tinted glass going in the car. 70 is on the right and the later ones on the left
Re: Updated
[Re: JDMopar]
#730807
12/03/10 07:13 PM
12/03/10 07:13 PM
gtx6970
It's a dry heat
Lookin good Bill. If the AC compressor lines up correctly to use 2 belts as the original does...I'd use them. I've got Classic Air brackets on a small block, and it only uses one belt. It will squeel under load sometimes. Use 2 if you can.
Thanks fellas
JD, I tried and would prefer 2 belts, BUT the pulley alignment makes that out of the question.It's one belt or nothing.
Re: Updated
[Re: Desmond]
#730809
12/04/10 12:30 PM
12/04/10 12:30 PM
Posts: 2,554 Maryland
wally426ci
Maryland
Coming along nicely!! Great find as far as speakers! I had no idea 1/4 trim was different in 70. I love the location of the ECU!
Re: Updated
[Re: wally426ci]
#730811
12/04/10 07:23 PM
12/04/10 07:23 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Me either, is that just a Barracuda thing or was diff. on 70 Challengers also?
Joe
Re: Updated
[Re: jrwoodjoe]
#730812
12/05/10 05:23 PM
12/05/10 05:23 PM
gtx6970
It's a dry heat
Joe
Joe, as a far as I know Yes it applies to all E-bodies.
The vertical weatherstrip in this stainless steel moulding is unique to a 1970
Re: Updated
[Re: gtx6970]
#730815
12/08/10 01:19 AM
12/08/10 01:19 AM
Posts: 189 long island new york
kingdust
you do nice work. attention to details makes or breaks a car. its alot of work and its nice when you have the parts already there, seems like your getting alot done in a short amount of time. good luck finishing it.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
