Re: 318 head swap
[Re: tee-john]
#730102
06/21/10 08:07 AM
06/21/10 08:07 AM
Posts: 15,487 Florida
scratchnfotraction
yes they will i run a lunati 60710 VooDoo roller cam in my 360 headed 318 in my daily driver truck 258/264 207/213 .485/.485 the whiplash from hughes is a nice one with a lumpy lump lump idle to it also any of the lunati sb cams can use the comp 901-16 springs...drop on with stock seals FYI...lunati springs are doubles and need pc seals and machine work to go on a stock sb head
Re: 318 head swap
[Re: scratchnfotraction]
#730103
06/21/10 09:51 AM
06/21/10 09:51 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
it'll kill compression, hurting low end torque. compression will be in the 7's, unless you mill a fair amount.
the comp 901 springs will work with any cam up to about .495 lift.
cam, with the low compression, biggest I'd go would be a comp XE256 or lunati voodoo 60401 unless you are doing a piston upgrade or heavy milling.
a better head choice for a stock short block 318 are magnums. they outflow the 915's with smaller ports (better velocity=better midrange throttle response and torque), and have ~9cc smaller chambers than the 915's, (63cc vs 72) so you'll actually get a slight compression boost over even stock open chambered 318 heads (~68cc)...you just need to run hollow pushrods that are ~7.625" long and stock magnum rockers, and either redrill the heads for LA intakes or run a magnum intake.
hughes sells their "Iron Rams" (enginequest 318A/B magnum replacement heads) complete with their #1110 springs for $725...I'd probably run a voodoo 60402, comp XE256 or XE262, or engle 4418.
Re: 318 head swap
[Re: patrick]
#730104
06/21/10 10:14 AM
06/21/10 10:14 AM
scratchnfotraction
he said 318 4-v that will allready be low on comp with 360 heads so i would not think it will drop any more than it allready is with 915s
Re: 318 head swap
#730106
06/21/10 12:38 PM
06/21/10 12:38 PM
patrick
Grand Haven, MI
he said 318 4-v
I missed him say it was a stock 4v...that said, power and flow wise, he won't really gain anything power wise using some 915 heads over the stock smogger 360 heads a 4v 318 came with....not worth the cost or hassle at least, unless the heads that are on there are totally wiped....that money would be better spent on some KB167 pistons...
same thing with using 308's...really no flow improvement over smogger non swirl 360's (except in the magnum style exhaust port), but still has the huge, compression killing chambers.
after putting magnums on my stock long block '86 318 with a reground roller cam, I can't imagine a better OEM head for this displacement engine....
Re: 318 head swap
[Re: patrick]
#730107
06/21/10 03:47 PM
06/21/10 03:47 PM
scratchnfotraction
I like the #302 cast swirl port heads with 1.88/1.60 valves with a home pocket port also I like them on a stock 360 bottom end also for a truck/work engine...lot more torque with patrick,spend the $ on pistons unless the heads are shot completly my 360 headed 318 works nice in the 85 truck with the lunati roller cam for a driver,I followed patricks advice on that one and it works great for mine with the low CR
