Re: Which hemi car or truck
[Re: gtx69]
#72797
06/13/08 08:52 AM
06/13/08 08:52 AM
Posts: 1,564 St. Clair Shores, Michigan
bigsbigelow
I believe the mds in the trucks was introduced in 07. Might be 06, though. Can someone clarify this? I also wasn't specific enough before, the 5.7 hemis in the cars all have mds but the 6.1 hemis do not.
[Re: bigsbigelow]
#72801
06/13/08 09:27 AM
06/13/08 09:27 AM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
Why not use it if it's available? I drive my muscle cars for the muscle as well, but the time I actually USE that aspect of the car is MAYBE 1% of the time, being very generous. Granted, the time that I might be in the right parameters to engage the MDS might not be very frequent either, but I'd wager that it would be more often than WOT. I'd personally hate to leave any economy on the table, for those times that I'm driving to an autocross event, or cruising with my family out to the lake with the top down. If there's some reason that it renders the salvage engine inop, that's one thing, but I can't imagine that's the case.
Clair
[Re: burdar]
#72802
06/13/08 09:27 AM
06/13/08 09:27 AM
bigsbigelow
I know it only works while cruising but all I am saying is personally I would like all cylinders firing at all times and I would probably swap a carb. onto it as well. But if gtx69 wants mds then any year HEMI that came in a car will do.
[Re: gtx69]
#72805
06/13/08 02:21 PM
06/13/08 02:21 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
mds or no mds...does not matter. all the hemis and that includes the 6.1 have the provision for it. use the early truck or 6.1 mds plugs and get rid of the solenoid if its not wanted or needed.
mds wont work even if you use anything over a 20 weight motor oil also.
what concerns me is the chasis. the truck uses a high mount alt and a/c compressor.
the auto stuff is low and on the side.
check your chasis and see if one works better than the other. i prefer the car motor myself.
the cars use a much better intake manifold.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: gremlinsteve]
#72806
06/13/08 02:26 PM
06/13/08 02:26 PM
gremlinsteve
houston texas
mds uses too much information to activate it. you would have a wiring nightmare i think to get it operational. the lx cars themselves have 7 computers. each talking to each other.
the mds system uses oil pressure..oil temp...water temp...pressure on the throttle...vacuum reading.. just to name a few that need to be met to initiate its operation.
heck...they even set codes if the motor does not come up to temp fast these days. so adding low temp thermostats can be tricky at times.
if it was me, i would forgo the factory computer and run the motor without the mds ect.. they really are a nice engine that can make good power.
steve
[Re: gremlinsteve]
#72807
06/13/08 09:35 PM
06/13/08 09:35 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
i would recommend an 04 manual trans 2500 Dodge ram PCM. You do not have to worry about limp in mode with a manudal trans controller. A truck engine will fit in an a-body. One concern is the back of the intake is basically resting on the firewall/bulkhead. The alternator and compressor will clear the hood though. The car manifold is suppose to be better flow, and the no spark plug wires looks a little bit better on the later cars.
Good luck...
I have no experience with the MDS on a swap, so I cant give any advice there!
Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: Clair_Davis]
#72809
06/14/08 12:21 AM
06/14/08 12:21 AM
gremlinsteve
houston texas
a solenoid. its dropped in from the "lifter" valley area on these motors. remove the intake manifold on these motors, its dry so no coolant sees it, and you will see four plugs.
these plugs, again, are either plugged or use a solenoid. cyl 1 and 7 along with cyl 4 and 6 are mds. the solenoid dropps pressure to the lifter. the
the exhaust valve is cracked open using the system and the intake remains closed.
the computer drops the injector for the mds cyl at the same time.
its a very complicated system and only works on a stock computer. obviously.
again. the system reads alot of information that has to be met before it works.
if you change oil in the car amd move to 30 weight from the standard advised 20 weight oil, the syetm will not operate.
i have pics if interested.
steve
[Re: gremlinsteve]
#72810
06/14/08 12:24 AM
06/14/08 12:24 AM
gremlinsteve
houston texas
and again. wether you use a truck or car 5.7 or 6.1 depends on where you want or need the accessories placed in the chasis.
i prefer the 5.7 car intake. using it on a truck platform will give you grief tho.
a 6.1 intake can be adapted to a truck accesory drive tho. but in our testing. the 5.7 car intake on a 5.7 modded car motor out performed the 6.1 intake across the curve.
some have tested and shown slight increases tho.
i still prefer a carb intake and go from there..
steve
[Re: gremlinsteve]
#72811
06/14/08 12:40 AM
06/14/08 12:40 AM
gremlinsteve
houston texas
the truck style coil packs from the earlier years can be changed over to the newer style dual plug on single coil system. its a much cleaner look. lets you lose the long plug wires.
kits run in the 300-350 range.
comes with eight coil packs. the valve covers..pig tail ect..everything one would need.
steve
[Re: Clair_Davis]
#72813
06/14/08 06:08 PM
06/14/08 06:08 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
i am swapping every piece I can swap from a wrecked 07 Charger R/T to a 1970 GTX. The GTX goes to the paint stripper on Tuesday. The 5.7 came out of the donor car with ALL of the harness intact....very easy "plug-in" harness! I cannot say what "issues" will come up yet but our intent is to put everything in the GTX just like it came out of the donor car. I am POSITIVE we will encounter some curves, i.e. override ABS system for one,and who knows what else. The plan is to get it running as stock as we can then start tweaking it. The only drive train piece we won't be doing is the independent rear suspension (Air Ride 4 link w coil overs).I think this approach will be easiest not counting getting everything mounted in a reasonable way. The 5.7 will sit in an Alterktion instead of a "K" frame so the only clearance issues appear to be the oil pan. Wath my thread "major Score" on the general Discussion section for ongoing updates. We have some rust issues (imagine that) to deal with first so it will be a little bit but this project is moving right along. Got the wreck from copart for what I thought was a real good deal considered it still ran and drove.
Driving modern convenience in classic beauty
