360 spark plug choice #728085
06/19/10 02:15 PM
06/19/10 02:15 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
What would be a good choice for a spark plug. 360 12.8-1 comp, j heads 2.02 intake, VP110 fuel MP.509 Cam. strictly strip
Re: 360 spark plug choice [Re: flatiron] #728086
06/19/10 02:42 PM
06/19/10 02:42 PM
San Diego
formula S Offline
formula S  Offline
San Diego
autolite 3933 race plug
Re: 360 spark plug choice [Re: flatiron] #728087
06/19/10 02:45 PM
06/19/10 02:45 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Nice combo!!! Any flow numbers on the J-heads?? What intake you using???
Re: 360 spark plug choice [Re: MIKES_DUSTER] #728088
06/19/10 06:43 PM
06/19/10 06:43 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
with J heads...AR-51 Autolites
Tony
70 AARCuda Vitamin C
Re: 360 spark plug choice [Re: 70AARcuda] #728089
06/19/10 09:11 PM
06/19/10 09:11 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
NGK R #9
Re: 360 spark plug choice [Re: 70AARcuda] #728090
06/19/10 09:55 PM
06/19/10 09:55 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
This......or if you want a shelf plug with a non projected tip use Autolite 403's.
Re: 360 spark plug choice [Re: abodiesonly1] #728091
06/19/10 10:00 PM
06/19/10 10:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Or a Champion C59Y or YC, or 61 (warmer). Y has the finer tip, both 5/8" hex, projected tip.
Re: 360 spark plug choice [Re: topside] #728092
06/20/10 11:03 AM
06/20/10 11:03 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
NGK 5671-9 for a 13/16" socket
NGK 5671A-9 for a 5/8" socket
Re: 360 spark plug choice [Re: flatiron] #728093
06/20/10 12:11 PM
06/20/10 12:11 PM
San Diego
formula S Offline
formula S  Offline
San Diego
All the plugs that are posted here are exactly the same heat range, so you have a couple of choices to make 5/8" or 13/16", standard or extended tip, and what brand you like. As I posted AR3933 is 5/8" standard tip and AR3910 are the same heat range but with an extended tip. I have ran them both and both work fine, the AR51 has a 13/16" socket size and the AR3933 and AR3910 use a 5/8" socket I like the 5/8" because it's smaller and sometimes you might need a little more room around the headers
Re: 360 spark plug choice [Re: formula S] #728094
06/20/10 12:48 PM
06/20/10 12:48 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I could defintly use a bit moreroom around the headers thanks for the many suggestions
Re: 360 spark plug choice [Re: flatiron] #728095
07/12/10 10:21 AM
07/12/10 10:21 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I currently have champion RN11YC4 in my engine and I would like to.
Go a few heat ranges lower.
stay with a 5/8 plug.
Be able to get them over a parts counter like advance or auto zone. I really liked NGK'S in the past.
