Re: Need advice 440 water in oil
[Re: rtandy]
#727939
06/19/10 08:16 AM
06/19/10 08:16 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
most times a 440 head bolt holes don't get to water so bad gasket or did you replace dowel pins with longer ones and they are holding the head off?? If it's not that something is leaking heads or block may be poris??? When you exhaust all your options or first try http://irontite.com/store/index.php?main_page=index&cPath=1if you are going to use anti freeze there is one for that but the straight water one works best. Good Luck The all weather is compatable with antifreeze the ceramic is not!
[Re: buildanother]
#727945
06/19/10 11:42 AM
06/19/10 11:42 AM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
440. No coolant in intake man.
OOPS! I'm into small blocks, I didn't think they would be that much different. My lesson for the day.
