Stupid Exhaust Tip Question #727487
06/18/10 01:42 PM
06/18/10 01:42 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
I know this will appear to be a dumb question to most of you guys in the know of things, but here goes..... What size exhaust tip would I need so that the tip will slide over the outside of a 2-1/2 dia. tailpipe? Again, sorry for the dumb question. Thanks guys.
Re: Stupid Exhaust Tip Question [Re: GETX] #727488
06/18/10 01:57 PM
06/18/10 01:57 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
Generally what you're looking for is a 2.5" tip with a slip on style. That means it will slip over a 2.5" pipe. Check summit, they have a million different ones available.
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: Stupid Exhaust Tip Question [Re: GETX] #727489
06/18/10 01:57 PM
06/18/10 01:57 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
If I understand the question correctly you just look for a exhaust tip for a 2-1/2 dia. tailpipe
For example if you look at this catalog it tells you what size exhaust they fit.
http://www.ttiexhaust.com/Exhaust%20Tips/Tips.htm
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Stupid Exhaust Tip Question [Re: HealthServices] #727490
06/18/10 07:48 PM
06/18/10 07:48 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
So I am now to understand that any "slip on" style tip will be an I. D. (inside diameter) measurement and the tailpipe an O. D. (outside diameter) measurement. For examle:
Tailpipe 2-1/2 O.D.
Slip on tip 2-1/2 I.D.
Would this be a correct assumption?
Thanks for the replies guys .
