.533 320 Mopar hydraulic have big block cam
#727456
06/18/10 12:52 PM
06/18/10 12:52 PM
Posts: 903 Oregon
rtplumcrazy1
have any of you ran this cam-i have this cam in my 440 70 Challenger-probably 10 to 1 compression, stock intake, factoty exhaust manifolds, holley 850-i know that this is not the best cam choice. My car is a 4 sped car. How radical is this cam at idle-and how did i run overall. thanks
Put a big block 4 speed Scat Pack Dodge in your garage.
Re: .533 320 Mopar hydraulic have big block cam
[Re: rtplumcrazy1]
#727457
06/18/10 01:20 PM
06/18/10 01:20 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I ran on for years with ported 906 2.14 1.81 valves works good works way better advanced to 102 to 104. Needs all the timing in bye 1500. For you probably a poor choice go with the .509 in at 102. makes a good 4 speed cam.
[Re: Dodgem]
#727458
06/18/10 02:26 PM
06/18/10 02:26 PM
Posts: 5,166 CT
GTX MATT
CT
I think that cam is a comeplete waste. Its way too big, by the time it starts out pulling a 509 cammed engine the RPMs are too high for hydraulic lifters anyway, unless you have a stroker.
With a stock intake and manifolds I think you're going to be very dissapointed. The idle will be very rough.
